Bllinda (3rd March, 2018)
A remote key, ordered by vin.
Learned with pin.
Might that work!?
rob h (1st March, 2018)
I could prepare remote by dump bcm, need write rcfg and rsk
@Reks13
Is it possible to wet the prepared remote? Thx
P.S. I upload a damp
A topic that interests me
I precoded by abrites and coded by obd. All ok.
I do not have MiraClone either tango.
I do not have either Abritus nor vvdi2.
Cpf,7946/47.... ....
xx xx xx xx sn/ide These data relate to immobilisation
4D 49 4B 52 cr/isk/lo
00 00 4F 4E cr/isk/hi
06 AA 48 54 tmcf/psw
4D 49 4B 52 psk Lo
00 00 4F 4E psk Hi
ar
00 00 00 00 psk/Lo and these data relate to the central lock.
00 00 FF FF psk/Hi
xx xx xx xx pcf/(RCFG)
xx xx xx xx sync
body bcm .rar (855 Bytes, 4 views) archive pass:reks13
What needs to be written to the transponder?
To make a central lock and inmo?
Thank you all for the answers. Men.
i dont think any one nows the remote config i try to figure it many times but not succesfull i use avdi ori and tmpro 2 original it simply just works on fiat based cars so i stopp try figure it out
tango only do transponder
p1et (7th March, 2018)
@Bllinda
I made a key with a remote control but with TMPRO, I wanted to locate where the RSK Lo, RSK Hi and RCF in eeprom but key made by tmpro write config (page 3) FF AA 48 54 so unable to read remote data (ISK Lo, ISK Hi found by ioterminal) maybe next version iot do this (now full support all kind fiat delphi body)
In Jumper Marelli BCU with 95640. I program with original AVDI Fiat key tool, i set right PCF7946+10/16 SSOP Chip (key is pcf4946 with 10 SSOP), but remote not work right. Unlock button lock car, other not work. Programmer with Diagbox, car run but remote not work right.
How can solve this problem ?
fricker (2nd April, 2018)
