Try 8281 mate
Try 8281 mate
kiszka (2nd August, 2017)
try 8182 or 0230
Pin is definitely 8281 mate..
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
agc (16th August, 2017)
I didnt read that as time block running?
Did read it as security counter reset 2 times, and vin changed 4 times though..
edit: Right, I've loaded the dump onto one of my own clocks.. security time is NOT running and also I could divorce / reset the unit without any problems with the code given. Checked with tech2 and opcom.. Also identifier is coming back as 0x0000 in case anyone was wondering
Reality of life :
3:Everyone lies
What does it mean active time block? Code is good for instrument and body module but cim does not accept 8281 what can be wrong?
Išsiųsta naudojantis HUAWEI TIT-L01 Tapatalk 4 Lt
Turn .... ....
A topic that interests me
thank you my point is proved
No time blocks.. I had installed this bin file already on to my own clocks to prove if it is running or not and as stated previously it was not.. the guy here as you can see has a CIM unit issue not accepting the code not the clocks...
Time block = security wait time. This happens when the security code is entered in wrong more than a few tiimes, it starts a timer running which makes you wait before the next attempt..
Reality of life :
3:Everyone lies
Reality of life :
3:Everyone lies
