Results 1 to 15 of 28
    Aug 2015
    BEHIND YOU
    Default bmw x3 2012 big problem after mileage change. need help
    hello i have do mileage adjustment for bmw x3 2012
    cas4 done with vvdi prog
    dash with r270
    i have remove first cas and dash.... i have do the cas and put on the car... customer turned on the car and drive it for about 20 meter without dash..... after i have do dash i have plug it to the car... when i turn ignition all light are working.... but when i start the car on only i can see mileage...
    speed needle is the only that work....
    when i do a dash test with a scan all needle are working and all light...
    i get this message on the screen : instrument panel update required. have the system checked by the nearest bmw center
    22365267_10159456868040494_7409728693446108629_n.jpg22449769_10159456868000494_8424854314305648559_n.jpg22365267_10159456868040494_7409728693446108629_n.jpg22366408_10159456867940494_6931570432641449447_n.jpg
    i will appreciate any help
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
    levisdj's Avatar
    EcuLand
    Cas should be 0 and dash the value you need... how did you do it ?
    Aug 2015
    BEHIND YOU
    this is the 4th car that i have do
    i have put cas to 0km
    and dash to the desired value.... new mileage value appear...
    the problem is that only speed needle is working...
    do you know anything about this message instrument panel update required. have the system checked by the nearest bmw center
    and do you know if the car was started and driven without dash pluged .. if this will make any problem >??
    salkapone's Avatar
    Oct 2013
    you now have backup.....write original eep to dash and see !!! or take out dash read eep and compare with original one from backups.....
    Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
  5. The Following 2 Users Say Thank You to salkapone For This Useful Post:
    doctore (12th October, 2017), Drdiag (16th October, 2017)
    levisdj's Avatar
    EcuLand
    the way I see it, could be that the eep data was not written completely, or the eep has gone bad... when starting the car it increases voltage, but as salkapone said, put orig back and see how it goes.
    neuro's Avatar
    Dec 2010
    UK
    As Salkapone mentioned, load ori dump to eeprom in cluster and see if everything is working fine, done few days back F11 2011 with cas4 , i never put 0km just 1024km as it will take out value during sync, and used car for 2 days without cluster, then 2 days later done cluster and everything is okay, so yours eeprom reading is corrupted and you need to use backup, or if you dont have backup you need to flash dash using ICOM or any compatible passthrough cable with ISTA-P
    Aug 2015
    BEHIND YOU
    i have compare the old and the new dump there is 512 byte mismatch.... when i put old eeprom same thing and eeprom get corrputed again..
    if i read many and many time outside the circuit eeprom data is the same..
    the problem is that some byte are changing when i solder eeprom back to dashboard...
    so what do you think ?
    neuro's Avatar
    Dec 2010
    UK
    i think you need to flash instrument cluster with ISTA-P
  10. #9
    Mar 2011
    Vilnius,Lithuania
    you lost half eeprom data because you read and write 160DQW like m35080
  11. #10
    Nov 2011
    Macedonia
    Quote Originally Posted by eliaselias View Post
    dash with r270
    I had a similar problem but not with bmw .... this is astra H ...... broken eeprom .... try to replace it with new 160DQW
    Baze007
  12. #11
    Aug 2015
    BEHIND YOU
    problem solved by coding dash again to the car at bmw dealer
    cost was 100$
  13. The Following User Says Thank You to eliaselias For This Useful Post:
    talk2idris (17th October, 2017)
  14. #12
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    cost was 100$
    And the km you ended up with was?
  15. #13
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by teerak2uk View Post
    before i went to dealer i wrote back original dump on cas and dash....
    they have re-flashed dash to the car ...now it working normaly...
    and after i have remove them again and do mileage correction...dash is still working
  16. The Following User Says Thank You to eliaselias For This Useful Post:
    teerak2uk (16th October, 2017)
  17. #14
    Oct 2017
    For the next time you can use E-sys for this. Most times after changing mileage retrofitting cluster the coding file is gone. You simply have to inject the coding file and it will work again.
  18. The Following 2 Users Say Thank You to larshutten For This Useful Post:
    teerak2uk (16th October, 2017), xm3n (17th October, 2017)
  19. #15
    Aug 2015
    BEHIND YOU
    hello i have a new problem after 1 week
    car look like dead ...car not start no ignition...
    i have read cas4 again... i have see big difference before and after car re-flash in D flash only.....P-flash is the same
    can someone compare and told me what is wrong
