Results 16 to 30 of 38
  1. #16
    Jun 2013
    Quote Originally Posted by falovell View Post
    Their official website say they can do all key lost as well
    My tool is on the way but I don't have a Q5 with me to test it
    This tool is pretty good to do Audi and Volkswagen
    It's not a clone of any device out there
    I have been aware of this version quite some time now.
    But it has only appeared on Chinese sites. And I guess only Chinese language.
    Is it now released for the market, in the rest of the world? With English language.
    And did you get any info about next years subscription. Usually they charge quite much, for updates on diagnostic tools.
  2. #17
    Not exist tool what can read Nec when is locked in bcm from 2014 and up.
    Only erase and after thta you can ,, read,,.
  3. #18
    Jun 2013
    Check the "Comparison" chart on this one. Says something about Audi 2015-2017
    http://www.aurodiag.com/aurocms/product1/702.jhtml
  4. #19
    Quote Originally Posted by wintesla View Post
    ////// exist mate /////////
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
  5. The Following 2 Users Say Thank You to koyot For This Useful Post:
    motorsport (26th January, 2018), wokounek (13th August, 2018)
  6. #20
    Jul 2016
    UK
    Doesn't say all keys lost though. VVDI2 read BCM data fine on a 2015 Q5 with a working key but wouldn't do a thing without. Could not read the data on the bench either.
  7. #21
    Link?
    Info?
    Quote Originally Posted by koyot View Post
  8. #22
    auragom not support component security
  9. #23
    HeXeN's Avatar
    Mar 2015
    do you think its encrypted? A6 C7 2014
  10. #24
    Germany
    I think it is depending on software version. With 0551 you should be lucky. I have one with 0650 all keys lost. No way. I cant read it on bench, because NEC is locked. Cant do it with VVDI2 with obd2, because service mode is not working on this newer modules. But then I got an idea: I readed out ECU (EDC17C46) by bootmode, decrypted immo data. This immo data I recrypted to an older bcm2 module, which I can read by UPA. I changed VIN, 16 Byte CS and Power Class from ecu to older BCM2. I think (or better said hope), that I can put this module into car, learn dealer key and start the car. If yes, I would install original bcm2 back and would try to adapt key with obddata generated with vvdi from old modul. I have not the car in my garage, but I will post result.
    Greets MR...
  11. The Following 3 Users Say Thank You to brobble For This Useful Post:
    jacostanzo (1st September, 2018), MarkPRP (7th October, 2018), rob h (28th August, 2018)
  12. #25
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Why do such dificult manipulations when key at dealer cost 260euro. For experiment?
  13. #26
    Germany
    In my case it is a stolen and recovered car. Most modules are changed from other car. Dealer want´s to give the car new identity. This means, new locks, new keys, new bcm2, new ecu. And now we are not talking about 260 Euro anymore... :-) And for experimenting of course.
    Greets MR...
  14. The Following User Says Thank You to brobble For This Useful Post:
    rob h (29th August, 2018)
  15. #27
    Jul 2016
    UK
    Sounds like it could be a faster method than waiting for the dealer key if the customer is in the a rush. Old unit can sourced very cheaply.
  16. #28
    Bllinda's Avatar
    Baltic
    Ora5nge or NEC.PRO can not read NEC.MCU locked?
    Did you try in UART or SPI mode?
    Quote Originally Posted by brobble View Post
    Greets MR...
    today
    A topic that interests me
  17. #29
    Dec 2010
    Greets MR...
    In that way seems to work... in real world I don't know, i'm very curious to know if work, good luck. Let us know the result when you do it!
  18. #30
    Quote Originally Posted by amigokola View Post
    Got lucky
    VVDI2 managed to do it.
    It was 8K0907064JG BCM2 2.0 H14 0650.
    Date on BCM was 09.2014.
    All keys lost or spare key ?
