Page 47 of 270 FirstFirst ... 3742434445464748495051525797147 ... LastLast
Results 691 to 705 of 4036
  1. #691
    Hampshire
    Ok guys,thanks for all sggestions,will update the post.cheers
  2. #692
    server work?
  3. #693
    Hampshire
    Just an update, I programmed the old and new key again, under the standard method, identified as can A3, then proceeded with the key programming, then I saw the "Safe" turned into 1/1, then safe again with the second new key, so I guess faulty chip, or precoding, the owner then decided to take it to dealer. So I am sure the new chip and 7bite precoding would have sold this problem, thanks all for your input.
  4. #694
    Aug 2015
    Vag 35 is out but again no more info about mqb all keys lost, which was pronounced at alex locksmith show
  5. #695
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Quote Originally Posted by offsystem View Post
    if like me you don’t want to ~~~~ the customer car
    then forget it
    cos once file written to cluster
    no other tool will read car
  6. The Following User Says Thank You to whiskeyman For This Useful Post:
    PremierD (16th November, 2018)
  7. #696
    Fallen's Avatar
    Quote Originally Posted by whiskeyman View Post
    then forget it
    Seriously?
    The Abritus solution will block access to VW dealers?
    That does not sound like a solution to me, sounds more like a lawsuit!
  8. #697
    Dec 2012
    EU
    Is any one using daily this new kia update for pin reading....anything i try 2016 upward dont work...
    Last one i had is sportage new shape 2016 up..and pin fail.
    Sent from my SM-G955F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  9. #698
    Feb 2014
    It failed on me with a Sportage 3rd gen, too. None of the options worked and I don't have a sniffer.
    KD-X2 decoded the PIN effortlessly from the working key, instead.
  10. The Following User Says Thank You to autoTkey For This Useful Post:
    PocketHero (19th November, 2018)
  11. #699
    Sep 2016
    Quote Originally Posted by gttuning View Post
    It was smartkey? They copied some functions from Londsor and charge for that like for Londsor But Abritus claims to do almost 100% of cars.
  12. #700
    Dec 2012
    EU
    Tucson 2017 regular key..
    This is maybe 7th car since i bought update and not one worked for me..
    Tryed with wo r king key and sniffer fail as well.
    Any one have manage to read pin...
  13. #701
    foxtec800's Avatar
    anyone used Vag Mqb 2012-2014 ? Tried on 2 octavia`s now and both failed to unlock security so had to order dealer keys and code with ODIS,,
    What`s the success rate on the new software ?
  14. #702
    ghostrider72's Avatar
    Jul 2012
    UK
    Its not working on all clusters. It fail on me on mk7 tdi. But it was JC clocks so no wonder
  15. The Following User Says Thank You to ghostrider72 For This Useful Post:
    foxtec800 (26th November, 2018)
  16. #703
    Dec 2012
    EU
    Quote Originally Posted by qeso705 View Post
    I tryed booth regular and smart...fail.
    Yesturday had sportage 2017 fail again
  17. #704
    Dec 2012
    EU
    Quote Originally Posted by foxtec800 View Post
    Done few and worked ok...
  18. The Following User Says Thank You to gttuning For This Useful Post:
  19. #705
    M3L3R's Avatar
    Mar 2014
    Kolobrzeg
    I couldnt coding smart key for ford fiesta 2015 AKL - X100 done job
    Seat ibiza 2006 key programming doesnt work(spare key) - VCDS did it by pin
    Skoda octavia 2006 immo light flashing after key programming(spare key) - VCDS fixed it
    Volvo S60 2016 clear crash data doesnt work
    Range Rover evoque 2017 change mileage doesnt work
    Decoding CS from CCM in passat doesnt exist - vvdi decode it in 20sec
    Not possible to coding gearbox dl501 gen2 to audi S4, they said that its possible to coding gearbox unit up to 2012, my one was 2014
  20. The Following 3 Users Say Thank You to M3L3R For This Useful Post:
    chcp (25th November, 2018), nenadgorgi (25th November, 2018), PocketHero (25th November, 2018)
