Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 52
  1. #16
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    you must upload here files from Bcm and dash.
    Bcm and Dash have a 24c16 eeprom inside
  2. #17
    Aug 2011
    Quote Originally Posted by fytfh View Post
    today i recive gm mdi j2534 interface but i dont have subscription
    $40 GM subscription good for 2years for one vin.,reflash bcm,dash and immo
  3. #18
    Jan 2013
    Quote Originally Posted by arpi View Post
    give me more info pls
  4. #19
    Jan 2013
    Quote Originally Posted by jomberykaso View Post
    readed both dash and bcm
  5. #20
    ascrap2003's Avatar
    Sep 2016
    Texas
    Try writing vin to dash via dump if that don't work then maybe GM online flash to update dash to car. Need dealer tool! Any dash error or odo - - - - -?
    Had a issue Had a issue with my uploads so if you see one of my posts and need that dump let me know and I'll post it!
  6. #21
    ttzag's Avatar
    digital-kaos
    try this dump
    VIN edited
    Actions speak louder than words
  7. #22
    Jan 2013
    Quote Originally Posted by ascrap2003 View Post
    dahs error have only and is :wrong immobiliser code
  8. #23
    Jan 2013
    Quote Originally Posted by ttzag View Post
    try this dump
    VIN edited
    the same not work
  9. #24
    Jan 2013
    nobody can help me?
  10. #25
    Sep 2013
    Default Try this file and report if it works
    Good Luck!
  11. #26
    Mar 2017
    Colombia
    Your problem can not be fixed here....
    you must use the GM scanner and program in data line with server
    WINNER THE LOSER
  12. #27
    Jan 2013
    Good Luck!
    thanks not work i have changed before ving pgs2stn and pin code and is the same not work dtc is incorrect immobiliser identifer recived
  13. #28
    Mar 2017
    Colombia
    your failure is not a bad help for all members, it is not having tools to diagnose your car
    this problem is only fixed with GM MDI on direct server.......
    stop and I'm here and find an agency for them to solve it ..
    do not waste more time...
    I would like to be able to help you better but it is useless what is done in bank
    WINNER THE LOSER
  14. #29
    Jan 2013
    Quote Originally Posted by automotrizVIP View Post
    i have gm mdi my friend
  15. #30
    xm3n's Avatar
    Jan 2017
    Agree to this but cluster must be matching ID or else dealer cant fix
