dash does not need to code on cruze ,
need same gasoline engine dash.
dash is same and is from the same car but not work have dtc wrong immobiliser code
and vin number is incorect
no is gasoline cruze 2010 1.6 automatic
if you are sure thats your second hand dash is from gasoline too change the eeprom 24c16 from old one to your new one.
if not need to flash mcu too..
i not have old dash
maybe now you should try to sync dash from dealer only..
they can fix
Post or dash dump and BCM dump i will try to add VIN but not sure about IMMO
dash dump 24c16 or d70f3423
i speake with dealer but told me need to be installed new cluster
nobody know procedure for this cars?
you dont have j2534 interface with GM subscriptions? or a friend that have it?
sharing is the key of success
today i recive gm mdi j2534 interface but i dont have subscription
