vvdi prog all day long or ori upa
datapage (17th August, 2018)
License CPT v850 RECOMMENDED
Tanks .....
CARPROTOOL NOW ALL OK.
reading ok.
New source higher amperage.
review voltage pin vcc cpt2.
voltage below 3.5 v is not read.
voltage now 4.5v. reading 100%.
Can someone do a virgin? or vin edit + elv off?
vin car 3D4PG6FD6AT254388.
you KNow PIN code adress ?
_______________ D3-oToprog _________________
ig : vanos_batam
code.flash or flash.file ....
A topic that interests me
Vanos, código pin 7786 ecu second hand.
data flash 64k.
imo code repeat 16x
vin code repeat 16x 4blocks x 4 positions +1 .
vin manual edit hex edit= ok
CARPROTOOL 100% WORKING.
narkeleptk (29th January, 2020), vanos batam (11th September, 2018)
can someone make virign ?
WIN P05026647AJ
or write pin code 8948
VIN 1C4RJFCM1CC302518
Thanks in advanced
Mat
Problem solved - i made virgin file by myself and then program WIM and keys to PCM with AVDI
Проблема решена - я сделал девственную файл самостоятельно, а затем запрограммировать WIM и ключи PCM с AVDI [/ QUOTE]
я положил блок wcm на своей машине. можешь помочь зделать этот блок девствинником?IMG-20211120-WA0015.jpgIMG-20211119-WA0002.jpg
Hello, please can you help me with the virgin file for Grand Cherokee WIN?
Hello, can you please help me with the virgin file for Grand cherokee WIN?
