Results 1 to 7 of 7
    narkeleptk's Avatar
    May 2017
    USA
    Default using 95640 in place of 95320
    I have a honda srs module with a faulty tssop 95320. Unfortunately I don't have that size replacement in stock. I will order some but to save time for my customer, Is it possible to substitute with a 95640 with out any ill effect?
    Write the original file normally to 95640 chip by 95320 menu and try.
  3. The Following User Says Thank You to Zmann For This Useful Post:
    narkeleptk (21st September, 2018)
    Aug 2011
    Yes will work,no problems
  5. The Following User Says Thank You to arpi For This Useful Post:
  6. #4
    narkeleptk's Avatar
    May 2017
    USA
    Welp, this IC burn up as well, looks like there is something wrong with module.
    >http://www.digital-kaos.co.uk/forums...om-after-crash
    Mar 2017
    аксай
    Можно.Я так делал.
  8. The Following User Says Thank You to toles For This Useful Post:
    narkeleptk (22nd September, 2018)
  9. #6
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    If the eproom is 95320 and u read with 95640 u get double dump
  10. #7
    slick_dick's Avatar
    Essex
    95640
    95128
    are all different in terms of file size
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
