Results 1 to 15 of 19
    waldi1979's Avatar
    Dec 2010
    Default Saab 9-3 BIG problem.
    I damaged dashboard of SAAB 9-3 1.9TID 2006.
    Later I tried to read 93LC66 from CIM, and I broke one the leg during cleaning (I'm very talented).
    I haven't got DASH and CIM dumps.
    I'm looking for the solution.
    1. I can buy spare parts from other car.
    What should I buy? ECU + Key(s) + Steering Lock + Dash +CIM + REC?
    What about other modules. Will they work? Radio, Door modules .....
    2. I have other working dash. If I find virgin CIM dump, wil I be able to program "new" CIM and used DASH?
    Where can I find TIS2000 for SAAB?
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  3. The Following User Says Thank You to kiszka For This Useful Post:
    waldi1979 (22nd September, 2018)
    Bllinda's Avatar
    Baltic
    Quote Originally Posted by waldi1979 View Post
    Logically, you are right.
    But practically Kiszka you are wrong about you, my friend.
    Quote Originally Posted by kiszka View Post
    if you have Tech2 with a saab card then you do not have a problem
    if you do not have it, it's best to buy the whole car for parts
    saab to jak opel vectraC wszystkie modóły są programowane do immo
    not forgetting about wines
    from today as you will see SAABA you will blow on Cold
    You can pull the pin from the REC or the front UEC or BCM and ECU
    today
    A topic that interests me
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
    brend's Avatar
    Oct 2015
    Same where
    Only dash ,and better if same like original or same year
    And for learning need Tech2.
    waldi1979's Avatar
    Dec 2010
    What about CIM.
    I need virgin dump?
    brend's Avatar
    Oct 2015
    Same where
    What about CIM.
    I need virgin dump?
    For what?
  9. The Following User Says Thank You to brend For This Useful Post:
    kiszka (22nd September, 2018)
  10. #8
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
  11. The Following User Says Thank You to kiszka For This Useful Post:
    brend (22nd September, 2018)
  12. #9
    brend's Avatar
    Oct 2015
    Same where
    And without Teh2 just nothing .......
  13. The Following User Says Thank You to brend For This Useful Post:
  14. #10
    narkeleptk's Avatar
    May 2017
    USA
    If you just broke the leg on 93lc66 in CIM just replace the chip don't need another complete module. You probably can even get a read still from the 93lc66. Just make some kind of contact with where the leg was. you should see a tiny contact area left.
    I have a virgin CIM file that you can add old keys into but you need a tech2, saab card & security access using saab global TIS in order to configure it. Like every post has mentioned. Do you have these?
    Not much of a dash guy so can't help there.
  15. The Following User Says Thank You to narkeleptk For This Useful Post:
  16. #11
    Meat-Head's Avatar
    Cut your losses, give the customer £50 and tell them to fkuc off.
    get a small nail file file plastic of chip back, hold wire on to reader, hope for best
  17. The Following User Says Thank You to Meat-Head For This Useful Post:
    McDowell (14th July, 2021)
  18. #12
    waldi1979's Avatar
    Dec 2010
    Quote Originally Posted by narkeleptk View Post
    I have tried several hours to read 93lc66, but no success. A leg hasn't been broken down, but it pull out inside chip.
    I have tech2 saab. I have other working dash (the same nr).
    Can you share virgin cim dump for me?
  19. #13
    narkeleptk's Avatar
    May 2017
    USA
    heat + prying = destruction
    If ic is stuck on pcb with a little glue on bottom then tiny twisting motions works much better then prying.
  20. The Following 2 Users Say Thank You to narkeleptk For This Useful Post:
    marcolr (3rd October, 2018), waldi1979 (22nd September, 2018)
  21. #14
    Bllinda's Avatar
    Baltic
    What is part number.ipc.and.cim?
    today
  22. #15
    waldi1979's Avatar
    Dec 2010
    CIM 12805558 AA
    IPC P12763129 (7553658)
