Results 1 to 15 of 16
    Apr 2017
    RS - Brazil
    Lightbulb Peugeot 3008 year 2011/2012 - BSI Clone - New Install and telecoding
    Good day 4 everyone,
    I need to install the new BSI instead of the old one (attached images).
    Can I just copy the eprom from the old one and record the new one?
    Look, the HARD number is the same. Just a few differences in numbers.
    The new BSI was purchased from the dealership through the vehicle's chassis and has never been installed in any vehicle. It is new, unused. However, it still needs to be scaled.
    "The problem with this vehicle is that after the battery has been turned upside down, it has started to malfunction, the windshield wipers work even with the arrow switch turned off, the air conditioning compressor does not work either. rain, arrow key and everything is OK, the problem is with BSI. "
    Now my question is whether I can just transplant the eprom from old to new or whether I'm going to have to go to a dealership to do this service.
    If anyone can help me, I'll be grateful.
    Bllinda's Avatar
    Baltic
    Post
    Upload bsi new damp'a here. And don't forget the archive password .... pass PM
    Quote Originally Posted by lucaslacerda View Post
    RS - Brazil
    today
    A topic that interests me
    Apr 2017
    RS - Brazil
    Quote Originally Posted by Bllinda View Post
    The new BSI has no dump, it was acquired new in the store ... Not yet used in any vehicle ... Still it has a DUMP with password?
    "The new BSI has no dump" = VIRGIN DUMP (original), that always be accquired by people !!
    Uploading this dump will not help you to solve your problem. What you can do with this new BSI are...
    - Reading new BSI VIRGIN eeprom and keep it in safe place. Finding the correct PIN code (from old BSI or engine ECU). And proceed this new BSI as "Replacement part" menu. Anyway you will need to enter some 100's items as configuration manually which are quite complicated. If you have some tool like FVDI, you can clone it for both flash and eeprom.
    - Going to dealer
  5. The Following 2 Users Say Thank You to Zmann For This Useful Post:
    Le-Mans (7th June, 2019), lucaslacerda (7th June, 2019)
    Apr 2017
    RS - Brazil
    Thanks Man...
    I dont have fvdi, but I have The pin code acquired from chassi on dealer...
    Thanks for your support... Ill do The manual telecode of 100 itens... Sad, but True...
    Enviado de meu SM-G920I usando o Tapatalk
    Hope the old BSI is still working, save all the config items and following it (save from the Config menu under "Pack Repair" and not another one outside!). Don't remember if PPS platform for 3008 still exist under Diagbox, the saved config PDF in PPS format is easier than DiagBox format to follow.
  8. The Following User Says Thank You to Zmann For This Useful Post:
  9. #7
    Apr 2017
    RS - Brazil
    Quote Originally Posted by Zmann View Post
    Many Thanks zmann, ill do how you teach...
    I have clone Diagbox... Can do?
    Thanks again
  10. #8
    I don't see any problem with the clone as long as if it could go through 3008 cars.
  11. The Following User Says Thank You to Zmann For This Useful Post:
    lucaslacerda (8th June, 2019)
  12. #9
    Apr 2017
    RS - Brazil
    need to present new keys when install fresh BSI? or if im using the existent pin code can i use same chip transponders existen on the car?
  13. #10
    All old keys that were belonging to the car can be reprogrammed.
    btw, when you save the BSI config file (DiagBox format), can you please upload I would check it. Engine ECU MED17.4.2 ?
  14. The Following User Says Thank You to Zmann For This Useful Post:
    lucaslacerda (9th June, 2019)
  15. #11
    Apr 2017
    RS - Brazil
    Yes, engine ecu os Me17. 4.2
    Ill read today and upload here for your check.
    Thanks again zmann...
  16. #12
    Apr 2017
    RS - Brazil
    Hi Zmann,
    How we combined, see the logs from OLD and NEW Bsi for peugeot 3008.
    Now my situation is as follows: after installing the new BSI, I have done the keys' telecodification, I presented the PIN code and everything worked out, but now BSI does not recognize the ECU, which was once paired with the old BSI. Do I need to reset the ECU ME17.4.2? or is it just a question of telecodifying?
  17. #13
    Don't have the password and may not be necessary to password ?
  18. #14
    Apr 2017
    RS - Brazil
    Pw in your pm
  19. #15
    You did not upload file in DiagBox format as I asked.
