Page 14 of 17 FirstFirst ... 491011121314151617 LastLast
Results 196 to 210 of 253
  1. #196
    Dec 2015
    Hi guys
    Does any one of you know replacement of the big orange electrolytic capatitor (original is 35v 1500pf 125*C) that is easly found on ebay/aliexpress
    Thanks in advance.
  2. #197
    castin's Avatar
    Oct 2015
    shortcircuit in this place. Any idea?
  3. #198
    Hungary
  4. The Following User Says Thank You to Pepita For This Useful Post:
    castin (15th December, 2017)
  5. #199
    castin's Avatar
    Oct 2015
    Thanx Pepita, what is the first current consuption after connect power?
    Pepita please send me biger scheme for this unit (if possible).
    ThanxI have heard that it is necessary to use a min. 10a
  6. #200
    Hungary
    Without solenoid valve: 0.2 ampere
  7. #201
    castin's Avatar
    Oct 2015
    I now, but for start converter i need min 10A powersuply?
  8. #202
    Hungary
    Yes, it's about 5-10 amps in operation.
    Can not you test the battery? (10 A through fuse)
  9. #203
    castin's Avatar
    Oct 2015
    Im try test on table, but my powersource is to low. Im try on car. Thanx for help and info.
  10. #204
    Mar 2013
    Could anyone tell how much ripple is on +130v line ,mine is stable but when loaded ripple is up to 50 volts ?
  11. #205
    Feb 2016
    Hi to all
    I have edu for repair but it have many voltage missing like some 12 and 160 voltage
    any idea
  12. #206
    Hi friends , i need info image of this components sB1
    Schottky diode ?
  13. #207
    mapexo's Avatar
    Mar 2017
    Germany
    interessed pinout for test screen posted?
    Quote Originally Posted by PierreTheron View Post
    Here a bench test
    Must draw at least 4 amps (I use spill valve these days)
  14. #208
    Jun 2009
    I have 2 drivers that should work and do not work. 170V on the 10uF capacitor is, the current consumption in the stand is 180mA. How to run it without a car? I saw someone connect the 50W bulb and give the signal from the generator to one of the two inputs. Just what signal, 0-5V or 0-12V rectangular whether it must have a proportional filling?
  15. #209
    Jan 2017
    My merida`s ecu got problems, desoldered and found a blown capacitor. What to check next ?
  16. #210
    Aug 2018
    East Pole
    Check the voltages...
