Page 12 of 17 FirstFirst ... 27891011121314151617 LastLast
Results 166 to 180 of 253
  1. #166
    Member aitistu's Avatar
    Timisoara, Romania
    Quote Originally Posted by PierreTheron View Post
    Hi Never had this component down yet ..
    hi
    which component ? ic's ?
    regards
  2. #167
    PierreTheron's Avatar
    Centurion,South Africa
    Quote Originally Posted by aitistu View Post
    hi
    regards
    Have never found short on these ic's yet ...
    How to know if they are giving problems ??? ( How to test )
    I have about seven dead units i could not revive with my bit off knowledge on them ....
    Bench test gets to pass on some off them but if installed on car it does not even start ... Can it be faulty 170v capacitor ????
    I can upload video off last bench test i did .. but car not even wanted to start .....
  3. #168
    This unit tested on bench did not work on car . What have I missed ???
    https://www.dropbox.com/s/3zx7k47t6rtcrn5/20160314_075247.mp4?dl=0
  4. The Following 2 Users Say Thank You to PierreTheron For This Useful Post:
    ascotauto (29th December, 2016), willyboy28 (19th May, 2016)
  5. #169
    Timisoara, Romania
    hi
    to test ic-s you measure with ohmeter about 600 ohm on capactor 10uf near 5v stabilizer 7805
    ~ 600 ohm is ok if you get something below ~30-100 ohm then you got a blown ic
    i get them all desoldered and measure between pins 7 and 14 + and gnd (did not find other method....)
    i had boards with those ic damaged which were blowing 2 x buz91 coil driver (edu draws about 7-8 amps for 5 seconds then blows buz91 an some printed circuit )
    capacitor 10uf 450v should measure ~ 8-11uf low esr 0.00 to 1 ohm (various caps measured from an working unit)
    if inverter works (you have 165v at capacitor) it doesnt mean the car will start , you have to check th bridge
    and the connections between bridge trasistors 2xbuz91 and 2x 2903
    also check 23p06v
    some boards get intrerupted circuits on the inside layers of the board, so all parts seem ok the edu doesnt work; had boards which started working when bent by corners,
    regards
    c
  6. The Following 9 Users Say Thank You to aitistu For This Useful Post:
    ascotauto (29th December, 2016), danielif (13th April, 2016), Dinero84 (23rd October, 2023), ecufix (4th September, 2019), einet (9th April, 2016), mexanico1971 (27th June, 2016), Osvaldo (8th August, 2017), PierreTheron (9th April, 2016), Radic8R (29th August, 2017)
  7. #170
  8. The Following 2 Users Say Thank You to aitistu For This Useful Post:
    PierreTheron (9th April, 2016), willyboy28 (18th May, 2016)
  9. #171
    Hello
    marking code=sSD , sAK, sB1, S43 ?
    all sot23. 3
    help please!
    regards
  10. #172
    Bllinda's Avatar
    Baltic
    you here ....
    sAK
    today
    A topic that interests me
  11. The Following 2 Users Say Thank You to Bllinda For This Useful Post:
    ecufix (3rd April, 2019), PierreTheron (13th April, 2016)
  12. #173
    Hello
    I see not sAK!
    sSD? And sB1?
    sB1 = B1 it is same= bas40?
    sKS=bss138n?
    help
    please
    regards
  13. #174
    HMMMMMMMMMMMMMMMMMM
    Mabe better try something else on google or download SMD values
  14. #175
    Timisoara, Romania
    hi
    AK= BCX70K
    SD = BSS138
    M02 = BST82
    just to be sure for sb1 and s43 could you point the location on board? pictures with an arrow ?
    sB1 = bas40-04v 2 x Schottky diode
    s43 = bas40-04v 2 x Schottky diode
    regards
  15. The Following 2 Users Say Thank You to aitistu For This Useful Post:
    ecufix (3rd April, 2019), mexanico1971 (30th June, 2016)
  16. #176
    Feb 2013
    please, where it should connect this pin
    it's urgent!
    thank you!
  17. #177
    Feb 2013
    if someone needs.....
  18. The Following 5 Users Say Thank You to crisgsm For This Useful Post:
    aitistu (22nd May, 2016), ascotauto (29th December, 2016), ecufix (2nd April, 2021), martinracing (15th July, 2020), mexanico1971 (17th August, 2016)
  19. #178
    hello
    OPEL ISUZU 8971891360 I have repairs, car start now, 15@30 MIN Car drive after, Making noise and no power, faultcode P0216
    HELP please
  20. #179
    mexanico1971's Avatar
    portugal
    Default ....
    as any see this situation " see pic "
    Is this comun issue , because is the 2st , I got here width this "blow" capacitador ,
    Replace the capacitor is enough , because I didin"t see any thing more damage ?!2016-08-08 15.44.36.jpg2016-08-08 15.44.51.jpg
    My work is my life ART TECH GARAGE
  21. #180
    belgrade,serbia
    hi,
    it is not capatitor it is resistor 0.5ohm.did you check fets because something is in short circuit
  22. The Following User Says Thank You to vladanr For This Useful Post:
    mexanico1971 (11th August, 2016)
