Hello
I hawe problem EDU opel corsa not working smd chip 014 = ? end 89951 =?
Please help
Hi !
thank"s for the Tip , but I think the issue is in the board , I change the resistor 0.5ohm and capacitor near but still got short in all components arround !
Maybe is that"s Smd"s marked as " 50510-J80775 "
If some one have see same problem width the "resistor 0.5ohm melted " please share !
Thank"s in advance
Brs
My work is my life ART TECH GARAGE
Hello
Please help
mexanico1971 (6th November, 2017)
.... .... 2901
014 - 7805
A topic that interests me
Thank you very much, this post is very usefull for this bull shit of EDU.
hi marjan, 898551=lm2901d; and resistor it is not 0,5ohm, it is 0,02ohm, an wiring it is wrong, not complete,
50610=lm2903n=lm358; sak=bcx70;sb1=bcx71
Hi freids,please help.
Can somebody help me with information where the red marked pin is connected? I've searched on board but I didn't find any straight connection.
Best regards
calc pompa inj 1opel.JPG here you are
ali kaptan (16th August, 2022), mexanico1971 (6th November, 2017), taxo1965 (17th March, 2017)
Hi freinds.This transistor is what series?Thanks.
Best Regards
taxo1965 (20th March, 2017)
Hi !
I have one situation that the car wont rev more than 3000rpm, EDU is problem !
any tips for component damage ?
In close look to the PCB nothing seems bad !!! I have resolded and check componennts
Thank"s in advance
See post #181 a pic with full pinout and voltage to test and without pass
on a rich or poor discussion - PL & SP blood - only on bench
HI
can you mark the Mosfet please
http://www.digital-kaos.co.uk/forums...6&d=1279669848
Hello guys, i have problems with the EDU of my meriva 1.7 2005, i tried some fixes posted here, but i didn't find the problem, was working one week last time i teared down, what can be the problem? How i can make a testbench? (i see some pictures but i dont know how to do it)
BTW i found this: http://www.cardiagnostics.be/-now/Re...mpenY17DTL.htm
any help is useful!
Tnks!
Current state of the board:
photo_2017-06-09_03-46-24.jpgphoto_2017-06-09_03-46-42.jpgphoto_2017-06-09_03-46-45.jpgphoto_2017-06-09_03-46-49.jpgphoto_2017-06-09_03-46-52.jpg
ecufix (4th September, 2019)
HI Guys
The BYV32 200 how many amps should be ?! 20 amps?!
And Buz91A 600v 8A is fine ??!
What references are you guys using ?!
thank"s in advance
Brs
