I formatted "Control Panel" My Diagun ... I hope there is someone who can help me to restore it. Thanks.
Restore DIAGUN
1.Soft RESET-reset button.
2.Hard RESET -A hard reset restarts the Diagun and erases all program data and system settings. After a hard reset, your Diagun returns to its default settings and loses all information that is not recorded in ROM.
To perform a hard reset:
- Locate the recessed Reset button at the bottom of the Diagun
- Press and hold down the Power button.
- Without removing the Power button, insert the stylus into the recess to trigger the Reset button. Hold down both the Power button and the Reset button until the screen fades off.
- When the screen has faded off completely, release both the Power button and the stylus.
- You will notice the Power indicator light up green, at this point, presas the Power button to turn ON the Diagun
laraiedh (6th April, 2020)
COPY and restore winCE registry
CeRegEditor - free registry editor for PDA PocketPC WindowsCE WindowsMobile(WM)
For connect Diagun with PC need soft ActiveSync.After install and connect Diagun with USB cable you have folder Mobile device in My Computer with Diagun file.
Open CeRegEditor and Connection-connect.You see registry.You can copy,edit,compare,restore registry Diagun.
COPY you registry and GAG file(in Storage Card)!!!
taxo1965 (22nd July, 2017)
My Diagun registry
Open with CeRegEditor
default.hv and user.hv-reserved copy registry(in Diagun)
1.Copy s3c2440_nr.exe in Storage card Diagun
2.Start s3c2440_nr.exe.
3.Save in Storage card.
4.in Storage card 2 file:Pages.bin and Spares.bin
File Pages.bin and Spares.bin open WinHex.Also can see file in GAG folder.
Copy Pages.bin and Spares.bin from Storage card (or http://www.digital-kaos.co.uk/forums...p-prosivka.rar) in PC folder FW. File Sorcery.zip unzip in FW.Start Sorcery.exe,Clear bad >Decomp
You have
NB00.nb0
NB01.nb0
NB02.nb0
NB03.nb0
chain.lst
In my Pages.bin i have 32 bad blok and i no have chain.nb0.Give forum you Pages.bin and spares.bin
This file i no testing!Error in file-Diagun died!
I ask in forum this file-FW-firmware from China.
Info from http://4pda.ru/forum/index.php?showt...0#entry2660676
I think NB00.nb0=eboot.nb0 LODER -format flash.NO use for live device.
This file(not nb00.nb0) copy in clear TF card formated in fat 16.
Sorcery.zip
My NB.Compare with you.
When i restore my diagun i also making report.
SERGEJ ! It think that better for testing and not killing diagun main unit will be this SANSUNG test board set to see how will cloning works (what do you think) ? :
Features:
CPU
- Samsung S3C2440A 400MHz, Max freq. 533Mhz
SDRAM
- 64MB SDRAM
- 32bits Data Bus width
- 100MHz Clock
Flash
- 256MB Nand Flash,
- 2MB Nor Flash, BIOS installed
LCD
- 4 wire resistive touch screen interface
- Up to 4096 color STN, 3.5 inches to12.1 inches, up to 1024x768 pixels
- Up to 64K color TFT, 3.5 inches to 12.1 inches, up to1024x768 pixels
- In box NEC 256K color 240x320/3.5 inches TFT screen, with touch screen
Interface and Resource
- 1 10/100M Ethernet RJ-45(DM9000)
- 3 Serial Ports(1 RS232 with CTS and RTS)
- 1 USB Host
- 1 USB Slave Type B
- 1 SD Card Interface
- 1 Stereo audio out, 1 Micro In
- 1 10-Pin JTAG
- 4 USER LEDs
- 6 USER buttons
- 1 PWM Beeper
- 1 POT can be used for A/D converter adjust
- 1 AT24C08 for I2C test
- 1 20-Pin Camera Interface
- 1 Battery for RTC
- Power In(5V), with switch and lamp
Oscillator Freq.
- 12MHz
RTC
- Internal
Expand Interface
- 1 34-Pin 2.0mm GPIO
- 1 40-Pin 2.0mm System Bus
Dimension
- 100 x 100(mm)
OS Support
- Linux 2.6.13
- Windows CE.Net 5.0
2. Content List:
(1) 1 S3C2440 board (Preload with Linux)
(2) 1 Serial cable
(3) 1 Net cable
(4) 1 USB cable
(5) 5V power adapter
(6) 1 JTAG board(for H-JTAG)
(7) 1 DVD-ROM with product reference
(8) 1 NEC LCD: 3.5", 240x320, with touch panel
3. Material list on DVD-ROM
(1) H-JTAG Debugger
(2) Windows Flash Programmer SJF2440
(3) Linux Nand Flash Programmer Jflash-2440(source code included)
(4) Serial tool CRT, dnw
(5) Bitmap to C Language transfer tool
(6) USB Driver(WindowXP/2000)
(7) vivi source code(linux bootloader)
(8) LED test program(ADS1.20 project)
(9) 2440test program(ADS1.20 project), include :
key test, RTC test, ADC test, IIS Audio play(wav), IIS Audio record,
touch screen test, I2C test, Samsung 3.5"LCD, 640x480 TFT test
(10) WindowsCE BSP and sample project files.
(11) Pre-compiled Win CE image for evaluation
(12) Linux tool and kernel source codes
- arm-linux-gcc-3.3.2 to compile Qtopia
- arm-linux-gcc-3.4.1 to compile kernel
- arm-linux-gcc-2.95.3 to compile vivi
- yaffs file system image maker -mkyaffsimage
- linux-2.6.13 for S3C2440 kernel source code(include DM9000, LCD driver, Audio,
Touch screen, YAFFS Source code, SD Card, RTC, Expand serial driver,
USB Camera,USB Mouse and Keyboard, U-Disk)
(13) Pre-compiled Linux image for evaluation
(14) Qtopia source codes, web browser source codes
(15) Schematics(Protel99SE/PDF)
I know about this device.This is good idea.But i no planning
strong work with Diagun.I think if we found pin JTAG in
Diagun we can restore and modify our device.
Send file possible with USB,Com port.But if died bootloader need JTAG.
Yes for backup in the end is urgent to know JTAG pins.But Im sure nobody will share info about JTAG pins in diagun, maybe Santa only So in this case with Samsung test board and multimeter help you can determin jtag pins in diagun because diagun use same flash and procesor ?!
