Page 361 of 854 FirstFirst ... 261311351356357358359360361362363364365366371411461 ... LastLast
Results 5,401 to 5,415 of 12803
  1. #5401
    Feb 2013
    An user from a different forum told me that 17.8.0 was released initially In July 2017 and then was re-posted in August, maybe at that point something changed...size, information, data etc.
  2. #5402
    Jul 2016
    Vilnius
    This applies for almost every release... e.g. the same 17.1.3. I have two installers with slightly different size
    * MK100
  3. #5403
    Oct 2017
    Good Morning, I to seek some help. I just purchased a 2007 Jetta 2.5. The guy who sold me the car gave me a laptop along with the USB cable. When i try connecting it keeps saying Can not ready. Then no response from controller. Can i make this work with my car? or what adapter should i buy. I have the ABS and Airbag light on and want to fix the car.
  4. #5404
    Feb 2013
    It might be with no License....or you need to launch vcds after you change calendar date..but first tell us what version of vcds it is installed on your laptop?
  5. #5405
    Jul 2016
    Vilnius
    The interface is decent quality but not perfect, I'd say. It can be reflashed to use the stuff which is floating around here.
    In order to accomplish that, you need to to the following:
    -Solder additional wires for programming as the interface does not have the dedicated pins for that;
    -I would suggest solder in a diode for OBD 16 pin for protection;
    -Your HW type is 0x44 and the chip is FT232BL. Clear it and program the dumps along with correct fuse/lock bits;
    -Use 17.1.3 version w/Loader and you should be good
    * MK100
  6. #5406
    xoom's Avatar
    Ylakiai
    Quote Originally Posted by JBeltran8 View Post
    First of all solder USB wires in place
  7. The Following User Says Thank You to xoom For This Useful Post:
    alexm1 (28th December, 2017)
  8. #5407
    Jan 2009
    @hid3
    Why do you recommend soldering the diode to pin 16 ?
    Anyone had a problem without such a diode ?!?
    just for my understanding....
  9. #5408
    Oct 2017
    Xoom. That was the first thing i did.
  10. #5409
    Jul 2016
    Vilnius
    Quote Originally Posted by Wene001 View Post
    @hid3
    Short circuit protection for "just in case".
    No, you won't haveany problems without it, unless something goes wrong.
    But.. High quality interfaces have it. It costs about $0.05, so why not to add it for peace of mind?
    * MK100
  11. The Following User Says Thank You to hid3 For This Useful Post:
    Pma54 (5th February, 2018)
  12. #5410
    [...] I just purchased a 2007 Jetta 2.5. [...]
    When i try connecting it keeps saying Can not ready. [...]
    1. I am not sure but your car is CAN Ready? Tried to make test on another car with CAN Ready?
    If yes and in your program in "About" screen having "License status: Valid/Activated", MCP 2551 and/or additional components can be damaged.
    But not always. Tell us-
    V
    2. As our coleagues asked you, what version of program using?
    3. ABS and Airbag are connected on K Line as i remember.
  13. #5411
    Jul 2016
    Vilnius
    This is Mk5 Jetta, so it is CAN-based.
    * MK100
  14. #5412
    xoom's Avatar
    Ylakiai
    The Diode on 16 pin is good for 2x2 adapter.. you can easy mix + and - becouse those adapters are like rubber and you can plug it wrong way..
  15. The Following 2 Users Say Thank You to xoom For This Useful Post:
    Pma54 (5th February, 2018), Wene001 (31st December, 2017)
  16. #5413
    Dec 2017
    hello everyone,
    i have old cable 12.12 with NEC D79F8513A, as I read here in forum no can with NEC update .....
    i muss buy new cable, there are two versions available NEC+RT232RQ or ATMEGA162+16V8B+FT232RQ ?
    which version is better?
  17. #5414
    Jul 2016
    Vilnius
    Re-read your own post once again and you will find the answer
    * MK100
  18. #5415
    Dec 2017
    i can buy with atmega, or buyer write me : that version ATMEGA162+16V8+FT232RQ is not stable, some customer said can not do some of the functions
