Results 1 to 10 of 10
    May 2017
    Default Nissan injector code
    I have a problem with fault code P0611 in nissan primastar 2.5 DCI ecu edc16c36 so i can't program the injector after obd read and write.
    if someone can help i need file injector from an other similar car to program it with kess v2
    Thanks for your help.
    Bllinda's Avatar
    Baltic
    upload here damp from.S.P.I
    today
    A topic that interests me
  3. The Following User Says Thank You to Bllinda For This Useful Post:
    MMAMINE89 (30th October, 2018)
    May 2017
    file readed with kess v2 the injector code was readed before egr off also the is in the car before remaping
    thanks for your help
  5. The Following User Says Thank You to MMAMINE89 For This Useful Post:
    chiper555 (12th February, 2019)
  6. #4
    rafal's Avatar
    UK - PL
    m8 as Bllinda said upload eeprom dump from ecu
    need help
    now my goal is to buy xp-005
    who will help?
    May 2017
    Hello freinds,
    Sorry i have a problem with my device
    This is dump readed with Ktag
  8. #6
    Bllinda's Avatar
    Baltic
    what is vin
    what kind of engine code
    Quote Originally Posted by MMAMINE89 View Post
    Hello freinds,
    Thanked 0 Times in 0 Posts .
    today
  9. The Following User Says Thank You to Bllinda For This Useful Post:
    MMAMINE89 (8th November, 2018)
  10. #7
    May 2017
    VIN : VNVU3C1K6UB023337
    Moteur : G9U
    Envoyé de mon SM-J730F en utilisant Tapatalk
  11. #8
    Bllinda's Avatar
    Baltic
    If you want to try, press the two buttons
    today
  12. The Following User Says Thank You to Bllinda For This Useful Post:
  13. #9
    May 2017
    it dosn't work,
    the car can't start
    the immo on
  14. #10
    Bllinda's Avatar
    Baltic
    You burn the SPI and need to be logged in with the programator
    P.S
    . Kess reads SPI as xx640
    today
