Results 1 to 9 of 9
    Mar 2024
    Default Help me 407 bsi pin
    Hello, I managed to read the eeprom of the Peugeot 407 bsi. I didn't solder it out, but with tweezers, I don't know how much this affects the result. The chip has this number 95128 3 .
    Well, my question is, can the bsi pin be deciphered from this, I looked in vain for the last 2 characters of the 60th line and the first 2 characters of the 70th line, but I couldn't find a solution, could someone possibly help me how to proceed. my question would still be that it must be soldered out of its place or it is possible to extract normal data from it with the help of tweezers. so far, I've tried a small ch341a chip reader, thanks in advance for your help Ziu.
    Jun 2013
    EU
    UF2L or reversed.
  3. The Following User Says Thank You to morgano For This Useful Post:
    Ziuron (18th March, 2024)
    Mar 2024
    what exactly does this mean UF2L ?
    Hayssam1's Avatar
    Nov 2009
    Germany
    Quote Originally Posted by Ziuron View Post
    He means reversed Pin L2FU
    Please Press Thanks Button and Reput if i helped !
  6. The Following User Says Thank You to Hayssam1 For This Useful Post:
  7. #5
    Mar 2024
    I feel so stupid, thanks everyone, I'll try it tomorrow
  8. #6
    Hayssam1's Avatar
    Nov 2009
    Germany
    you read the file correctly without unsoldering
    VF36ERHRH21387271
    363670 km
  9. The Following User Says Thank You to Hayssam1 For This Useful Post:
  10. #7
    Mar 2024
    Thank you very much for your help, the code worked, I was able to learn the key, everything is happy, only the door opening can't be taught, I don't think it's good, I bought the one with a chip, maybe you can find out from these data which is the key fob, ask or fsk? PCF7961 or PCF7941 ?? I don't know which one is right for my car because I didn't have such a key before, only a simple key.
  11. #8
    Bllinda's Avatar
    May 2010
    Baltic
    https://www.digital-kaos.co.uk/forum...php?f=174&a=32
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  12. #9
    Jan 2018
    try 0523 from xhorse
