Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
  1. #31
    Top Poster kristikapa's Avatar
    Dec 2009
    You are missing some files for the database or you didn`t copy the database files to the right folder.
  2. The Following User Says Thank You to kristikapa For This Useful Post:
    speedy100 (6th September, 2015)
  3. #32
    Member eudin77's Avatar
    Apr 2011
    near my pc
    Why you don't use an old version of ddt2000 like 2.0 or 2.3 ?
  4. The Following User Says Thank You to eudin77 For This Useful Post:
  5. #33
    speedy100's Avatar
    Jul 2010
    Athens
    Quote Originally Posted by eudin77 View Post
    Well they must have made some type of improvements and bug fixes to the newer version I guess....
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  6. #34
    dadal's Avatar
    Aug 2015
    I m looking for this versions ,, do you have a link ?
  7. #35
    Aug 2009
    I'm using DDT2000 light.Easy and stable.Tryed to connect on banch to ems3132 and sirius32n with vag k+can commander, but with unluck.
    Softer working normally like using KKL, but without comunication between vag k+can and ecu.
    I think need special addon.
  8. The Following User Says Thank You to flavyus1987 For This Useful Post:
    ALBERTO_ (29th September, 2017)
  9. #36
    Sarkan's Avatar
    Feb 2010
    Some instructions for installation that I found on the hard disk.
  10. The Following 17 Users Say Thank You to Sarkan For This Useful Post:
    5n4k3 (9th December, 2017), age9000 (1st November, 2017), Col19 (16th October, 2019), dupisa (19th September, 2017), issaqigu (30th June, 2018), joe06 (29th March, 2017), KWP2000 (26th November, 2017), nedved59 (12th May, 2016), olo_3 (13th November, 2018), rabihfiras (19th June, 2019), romucifer (11th January, 2017), sarigol45 (30th December, 2018), sasa5 (25th June, 2018), Shokunin (8th July, 2017), speedy100 (16th January, 2017), Stelaras (20th April, 2017)
  11. #37
    Sep 2009
    Fr
    Hi you have a parse error , please post a print-screen of the first page when open ddt2000.
    If not use older version .
  12. #38
    Jun 2016
    could some kind person direct me to where i can purchase ddt2000 please.
  13. #39
    Nov 2009
    if you want the software ddt2000 ,it is here in digital-kaos
    and also the interface schematic or use vag kkl
  14. #40
    Bllinda's Avatar
    May 2010
    Baltic
    I think that here is a mistake.
    what can cable will work with ddt2000?
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  15. The Following 3 Users Say Thank You to Bllinda For This Useful Post:
    Col19 (16th October, 2019), dupisa (19th September, 2017), speedy100 (16th January, 2017)
  16. #41
    Jun 2016
    hi ammarben.
    i cannot find it on this site,can u provide exact location please.............thanx.
  17. #42
    dadal's Avatar
    Aug 2015
    for cars on K-Line KKL cable
    for cars on Can-Bus Derelek cable ( if somone do know other option please share it )
  18. #43
    speedy100's Avatar
    Jul 2010
    Athens
    Quote Originally Posted by Freezzby View Post
    Well since i never got it working i am back with the starting screen and a Parse error... but i believe it is because of non connection with the "News server"...
    == XML-ParseError-SystemError_-2146697211 ==
    i have tried to insert a screen capture here but strange... it does not allow me to!!!
    B.R.
  19. The Following User Says Thank You to speedy100 For This Useful Post:
  20. #44
    dadal's Avatar
    Aug 2015
    Hi Mates
    I m using now windows 7 64, after installation I get error : xmlNews.parseError: cant find ,
    all folders are empty, I cant choose any ecu in menu
    antivirus is turned off, xml3 downloaded, other database tryed, still same problem
    older version of ddt no problem, but I want to use english version
    any idea ?
  21. #45
    Aug 2016
    Hola, gracias por los archivos de descarga.
    Una consulta, este software se puede usar con el ELM327??
    saludos Y gracias
