Results 1 to 11 of 11
    Top Poster nicolas2015's Avatar
    Feb 2015
    somewhere in cornwall
    Default Peugeot 307 2002 copy key+remote
    Hi to all, i need some info about how to make o copy of my peugeot 307 key. I found on ebay new key uncut, plus virgin chip, and board with buttons. The problem is that i dont have pp2000 or lexia to copy data, i have pin code, any idea, or any coleague in plymouth area? Thanks in advance.
    Vag-com, Op-com, Focom, Autocom,Multidiag, Forscan, Lexia....
    autochei's Avatar
    Mar 2013
    romania
    read eprom from ecu
    someone or me i give u pin code
    with autocom u can program transponder
    remote synchronizatuion after key programing put ign on and press button for 10 seconds
    that it s all
  3. The Following 2 Users Say Thank You to autochei For This Useful Post:
    nicolas2015 (11th July, 2016), vorovei constantin (12th July, 2016)
    p1et's Avatar
    Oct 2013
    He's got pin code . Just go to local locksmith and let them do this for you... Or buy some equipment... if you want do it by yourself...
  5. The Following User Says Thank You to p1et For This Useful Post:
  6. #4
    Feb 2015
    Any coleague in Plymouth area to help me with this key? Paying of course.
  7. #5
    Jul 2010
    west mids, uk
    If the remote board has been used then this will not work, post ebay ID to check.
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  8. #6
    Feb 2015
  9. #7
    Feb 2015
    original board and board bought that it supose to be virgin.
  10. #8
    kemaster's Avatar
    Mar 2010
    BG
    Quote Originally Posted by nicolas2015 View Post
    Suppose Ninja meaned ebay item ID (not seller ID)
  11. #9
    kemaster's Avatar
    Mar 2010
    BG
    Your new board seems like Chinese made. Haven't met such in original keys. If chinese it's questionable if will work. Can you post User page 0-3 content of your transponder.
  12. #10
    Jul 2014
    Sofia
    China remotes of this type usually work (surprisingly). All depends if you got correct type for the model, this is first byte transmitted by remote. If type is wrong remote will not work BUT you can make a backup before programming it to car. Then if programming is not successfull, you can use it again on another car. Just get a PCF7936 new carbon chip, write USER pages data to it and remove coil from remote PCB. Then you will be able to program it to another car without worrying that pcb can become useless after once paired to a car.
  13. The Following 4 Users Say Thank You to RFRemotes For This Useful Post:
    castin (11th November, 2022), Cesarec (8th March, 2017), gokart (26th July, 2016), reham (23rd September, 2016)
  14. #11
    Bllinda's Avatar
    May 2010
    Baltic
    or another thought here ....
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
