Results 1 to 12 of 12
    Nov 2009
    Default vw beetle pin from ecu
    can i get vw beetle pin from ecu thanks 2402 bosch 2000
    kiszka's Avatar
    Aug 2009
  3. The Following User Says Thank You to kiszka For This Useful Post:
    yugo45 (13th November, 2016)
    Nov 2009
    ok do i need pin to program key
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Use vag k+can commander and done without pin.
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  6. #5
    kiszka's Avatar
    Aug 2009
  7. #6
    Nov 2009
    could i get pin from dash please 912d60 thanks
  8. #7
    Jun 2013
    Dumps open fine.
    3 keys registered
    Does not come up with PIN in this case.
    If you find someone in your area. They could add it for you.
    Or maybe check out.
    Vag_Tac_o?
  9. #8
    Oct 2015
    Quote Originally Posted by sexyceta View Post
    if pin asked try 05120
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  10. #9
    Bllinda's Avatar
    May 2010
    Baltic
    try .... .... 9335
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  11. #10
    Apr 2011
    in lebanon
    Hello.
    yes the pin which bllinda share it here 09335 is the correct pin.
  12. #11
    Jun 2013
    Using other tool
    Yes pin is 9335
  13. #12
    kiszka's Avatar
    Aug 2009
