Results 1 to 13 of 13
    EARTH
    Default WCM ( wireless control module ) chrysler dodge jeep
    Someone could read this Dodge module.
    Cpt (Carprotool) did not read.
    Orange5 did not read.
    Jun 2015
    vvdi prog all day long or ori upa
  3. The Following User Says Thank You to Freebsd For This Useful Post:
    datapage (17th August, 2018)
    EARTH
    License CPT v850 RECOMMENDED
    EARTH
    Tanks .....
  6. #5
    EARTH
    CARPROTOOL NOW ALL OK.
    reading ok.
    New source higher amperage.
    review voltage pin vcc cpt2.
    voltage below 3.5 v is not read.
    voltage now 4.5v. reading 100%.
    Can someone do a virgin? or vin edit + elv off?
    vin car 3D4PG6FD6AT254388.
  7. #6
    vanos batam's Avatar
    Jul 2010
    Batam-Indonesia
    you KNow PIN code adress ?
    _______________ D3-oToprog _________________
    ig : vanos_batam
  8. #7
    Bllinda's Avatar
    May 2010
    Baltic
    code.flash or flash.file ....
    This is the current topic for me in 2022.10.
    508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
    today
    Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
    A topic that interests me
  9. #8
    EARTH
    Vanos, código pin 7786 ecu second hand.
    data flash 64k.
    imo code repeat 16x
    vin code repeat 16x 4blocks x 4 positions +1 .
    vin manual edit hex edit= ok
    CARPROTOOL 100% WORKING.
  10. The Following 2 Users Say Thank You to datapage For This Useful Post:
    narkeleptk (29th January, 2020), vanos batam (11th September, 2018)
  11. #9
    Apr 2011
    can someone make virign ?
    WIN P05026647AJ
    or write pin code 8948
    VIN 1C4RJFCM1CC302518
    Thanks in advanced
    Mat
    Problem solved - i made virgin file by myself and then program WIM and keys to PCM with AVDI
  12. #10
    Jan 2022
    tver
    Default привет! я новенький!
    Проблема решена - я сделал девственную файл самостоятельно, а затем запрограммировать WIM и ключи PCM с AVDI [/ QUOTE]
    я положил блок wcm на своей машине. можешь помочь зделать этот блок девствинником?IMG-20211120-WA0015.jpgIMG-20211119-WA0002.jpg
  13. #11
    Nov 2017
    Hello, please can you help me with the virgin file for Grand Cherokee WIN?
  14. #12
    Nov 2017
    Hello, can you please help me with the virgin file for Grand cherokee WIN?
  15. #13
    Jan 2018
    Quote Originally Posted by mcgywer View Post
    WIN P05026647AJ
    Thanks in advanced
    Mat
    Hi did you erase only vin and pin or something else?
    Wysłane z mojego SM-G715FN przy użyciu Tapatalka
