500CII poor quality
  • noclue2020
    500CII poor quality
    Hi im a newbie using above dream box. The picture and sound quality all of a sudden became poor, with garbled sounds and pixelated images... any help is appreciated. I can view all channels though, and it only started today, has been fine before.
  • DreamersDVB
    • 245
    500CII
    Have you try to set the picture mode to PAL?If yes than i suspect image going to be coruppted. I m not sure theres any firmware in local market to flash for this model unless the factory in China provide you.
    • kenngks
      • Oct 2010
      • 34
      Check for any loose antenna connection may solve the problem. Mine is worst which lost all the FTA channels. Could be a hardware problem and still looking for a solution.
      • ultrakiasu
        • 128
        When picture started to get garbed, it is an indicator of tuner is overheated and its internal circuitry may be permanently damaged.
        Few earlier batch of HQK3388/DM900C-II/DM500C used to suffer same issue, and I removed the motherboards and sent back for RMA, usually FOC repair in the first year.
        If its not tuner issue, perhaps u could check your antenna connection.
        • noclue2020
          oh my, its just about 5months old, and i got it from a friend of a friend so not sure where it was bought from. Is there a place for me to send it for repair?
          • housailei
            • Feb 2011
            • 5
            Hi, I have similar experience. I bought the DM500 CII and found that it's not what i want. It just a DM900C with DM500 casing. Then i replaced it with the supplier with true DM500C (with erthenet port and digital optic output), then all channels become clear. So better replace it.
