You want it. You need it. You've been waiting for it. Here it is....
1. Menu, Setup, Service searching, Manual transponder scan.
2. Enter frequency 00386 mhz.
3. Check INV box
4. Check Network Search box.
5. Start Scan
6. Look in All Services
7. Hey Presto!
8. WHAM!
9. BAM!
10. Thank You, Man!
please note;
I am running on a Dreambox500 but see no reason this wont work for your eurovox or whatever you have. Also This frequency (00386) is for my area of the midlands (cableuk sym6887). Apparently you should be able to find frequency for your area by finding a channel on your list called 'PVR_EPG'. Select this channel and then go into manual scan and make a note of the frequency. Go back into tv mode and select any ordinary channel (bbc, itv, sky1 for instance). Then go back into Manual scan, enter the frequency you have written down, check the INV box, check the NETWORK SEARCH box and start scan. And that should be it. If not on that channel try one of your 'DL PVR EXPLORER' channels.
You may have noticed my use of the word 'Apparently'. I used this word as this method is according to other folks on the forum who say it has worked for them. I have not tried it myself as the first method worked for me. I've only added this second method on the off chance that it will work for you or for your friends/family who live in different areas.
If none of these methods are any use to you then I am sorry for your loss. But don't give up hope, your answer is out there. Somebody will help you. We've all got to stick together in these times of Setanta-less sorrow.
Good Luck, Happy Hunting.
3. Check INV box
5. Start Scan
7. Hey Presto!
8. WHAM!
9. BAM!
10. Thank You, Man!
please note;
