how to delete channels 500c?
  • vitesse349
    • 60
    does anyone know how to delete single channels?
    im am runnung 500c with the 1.1 image. Can i do this via the remote? or do i have to use the FTP program?
    cheers lads.
  • Mubz
    • 168
    to delete from all channels 'ok red'
    highlight the channel to delete press menu, scroll down to delete and ok on that...
    its the same for bouquets too 'ok blue'
    if you are deleting form all channels and you have the auto search on,
    the channel will come back the next time the box self scans
    (top of my head i can't remember how to turn it off)
    Mubz
    Growing old is inevitable, growing up is optional ...
    • scuba
      • 198
      delete all the channels u don`t wont then go to setup>expert setup and scroll down till u see -disable service updates- tick it.Do another scan.
      • Mordor1946
        • 56
        single delete / addition
        Go into bouquettes....select 'red' (all channels) scroll to selected channel press menu button....scroll to required action i.e. add or delete ..press ok...
        • Gismogadget
          • 4
          First off go to menu the select setup
          now select parental lock
          make sure there is a tick at parental lock now change pin
          enter 1234 ok then again 1234 ok and when it says Pin change completed press OK
          now select hide locked services and press ok make sure there is a tick there also
          Now save
          now press exit
          now shutdown - reboot now....
          Now that parental lock is set up
          When you are on your channel list
          and you highlight the channel you want rid off select menu
          Service Menu should appear
          scroll up or down to lock and press ok
          that channel should now appear with a padlock at the end of it
          Do this with all the channels you want gone!!!!
          Reboot after you done that and Bang! the c**p channels are Gone
          This allows you to keep channel updates active
          • vitesse349
            • 60
            cheers fellas.
            appreciate all your help.
