New secondstage bootloader
  • veru
    • Nov 2010
    • 4
    #46
    Hi guys
    need some help here please, was getting CA error, box unusable when I last attempted to flash the dm800hd
    In the end managed get box to take a flash but it has no cccam and image is pretty crap nablio multiboot image
    I've logged into the box and its showing 75 r0 as boot loader, however on the webpage it says Booloader version Dreambox Second Stage Loader BUILD #72, built 20090303 ??
    Chap who's box it is tells me the tuner is rev S ? is there such a thing? he's updated tuner under a year ago.
    I basically want to update the bootloader so box will take a newer image
    Can I just flash any latest bootloader using dreamup / null cable?
    And then flash an image ontop?
    cheers
    • ypvs125
      • Dec 2010
      • 506
      #47
      Originally posted by veru
      Hi guys
      cheers
      Most clone patched images have the bootloader included so if u r on ssl75, if u flash with ssl82 or ssl84 images, it will automatically upgrade to the latest bootloader.
      Most important is find the correct image for yr sim card, else u will encounter ca error again.
      • tooloud
        • Mar 2010
        • 25
        #48
        no ca found
        so i have the dreaded no ca found, i have thrown everything at this for 3 days solid you name it i,ve tried it. whilst using an old dreamup i managed to get to the point where du waits for ok from the box after the checksum bit, i waited and i waited, but nothing frustrated i pulled the power and quickly plugged it back in. what i am about to post is what came up in du it means nothing to me but maybe it will to some of the more knowledgeable members, and who knows it may provide someone with a proper working solution to this dreaded problem.
        waiting for OK from box to beginn upload...Wrong response: 11.265 - load config
        dCA: not existent, loading defaults
        11.296 - config loaded.
        * press [S] to enter setup
        OLED found!
        lcd: BOOT #82
        - read config file: /boot/secondstage.conf
        detected jffs2 blocksize: 16kb
        dreamupd initialized
        Scanning JFFS2 FS: . | / - \ | / - \ | / - \ | /  done.
        find_inode failed for name=secondstage.conf
        load: Failed to find inode
        - failed to open /boot/secondstage.conf
        - failed to open /cf/autorun.bat
        lcd: /flash/bootlogo.elf
        bootlogo size: 213816
        *** BCHP: Invalid RTS setting detected. Forcing MEMC_0_CLIENT_INFO_7 (AVD_CAB_0) RR to true. Please see latest 7401 RTS documentation.
        no HDMI device detected
        no HDMI mode available, reverting to 720p
        using 1280x720p (60.00 Hz)
        create surface 1280 720
        Using the Small jpeg decoder library, Copyright (c) 2006, Luc Saillard <[email protected]>
        parsing JPEG header..
        Virtual FB Size: 1280x720
        lcd: /flash/vmlinux.gz
        <5>Linux version 2.6.18-7.4-dm800 (jediwarrior@RP5700) (gcc version 4.4.4 (GCC) ) #1 Sun Jun 26 00:44:19 BST 2011
        Fetching vars from bootloader... none present, using defaults.
        board_init_once: regval=44ac6502, ddr_strap=3, 4 chips, pci_size=2
        Detected 256 MB on board
        <4>WARNING: read invalid MAC address ff:ff:ff:ff:ff:ff from flash @ 0xbffff824
        Default command line =
        root=/dev/mtdblock3 rootfstype=jffs2 rw console=null
        1 831ffeb8 83029368
        g_board_RAM_size=256MB
        Options: sata=1 enet=1 emac_1=0 no_mdio=0 docsis=0 ebi_war=0 pci=1 smp=0
        CPU revision is: 00020000
        Determined physical RAM map:
        memory: 10000000 @ 00000000 (usable)
        ---> memsize from bootloader: 148
        User-defined physical RAM map:
        node [00000000, 09400000: RAM]
        node [09400000, 06c00000: RSVD]
        <5>Reserving 108 MB upper memory starting at 09400000
        <7>On node 0 totalpages: 65536
        <7> DMA zone: 65536 pages, LIFO batch:15
        Built 1 zonelists. Total pages: 65536
        <5>Kernel command line: root=/dev/mtdblock3 rootfstype=jffs2 rw console=null
        before init RAC 0x02a00000 0x00000000
        after init RAC 0x02a0000f 0x0fff0000
        19:52:54 Got wrong response from box: 11.265 - load config
        OLED found!
        lcd: BOOT #82
        1 831ffeb8 83029368
        hope this means summin to someone
        • simple74
          • May 2012
          is the latest one
          • kukoc
            • Nov 2012
            thank you very much
            • barbaros75
              • May 2010
              Originally posted by Parisno
              Heres a new second stage bootloader, I wont call it the anti-freeze fix, cos it did nowt to stop my DM800 freezing.
              same problem..but cant download. becaus not required
