new install
  • jckw
    • 760
    DM500 new install
    hi guys can anyone direct me were i can find firmware/software for my 500c its not preloaded
    we are all learning each day
  • scuba
    • 198
    u`ll find it here
    Digital Kaos - Downloads - Digital Kaos v1 Image for DM500 (cable and sat)
    • zemanepic
      CCcam
      How do we find the right CCcam version to use with each image?
      I instaled a PLI image and a CCcam and worked fine.
      Today i changed the image to Omega and the same CCcam did not install.
      Tks
      • scuba
        • 198
        ccam is usialy used for the sat boxes cable is best to be used with evocam 2.12 or 2.17
        • woody65
          • 7
          Hi All,
          I am newbie. I did new install following all instructions on "Totally spoonfed ...."document.
          I did the bruteforce auto transponder and picked up a lot of channels but I cant view many of them. No p*m channels are viewable, showing although the EPG is showing. Why might this be? What is missing?
          I powered off and then on again. This time it came up with the DK1.1 image in the background and it said running evocam2.12.
          I then pressed the blue button and it showed me 4 options:
          1. DreamNetcast Internet radio
          2. RSS Newsreader
          3. TuxBox Commander
          4. Teletext
          Nothing extra special happened. I am still unable to get my p*m channels plus B4U etc..something still missing. I am using DK 1.1 image and used Totally spoonfed document for flashing the box. Any help appreciated.
          • scuba
            • 198
            u`ll only be able to see free to air if you want to watch the rest u have to have a valid subscribtion or get on to the cardshearing
            • Dazmeister
              • 43
              I thought this was the Cable section not Satellite?
              @Woody65 - You still need to apply the fixes/updates (Nagraroms) before you can see any of the other channels like B4U, Sly 1 etc.
              Check out the link in this section for Updated Nagraroms. It's all there...
              And as for the p*rn channels, you will need to enter these manually, try this post
              It details SBO but later mentions the dirty birdy channels. Same method used throughout.
              • woody65
                • 7
                thanks will do -whats a nagroram?
                • gerrybhoy
                  Woody
                  Can you point me to the "totall spoonfed.." document, I'm makinig the jump from dbox2 to dreambox and could do with reading it.
                  • woody65
                    • 7
                    Originally posted by gerrybhoy
                    Woody
                    Its in the 'downloads' section under DREAMBOX, sub-category, guides.
                    cheers
                    W
                    • Dazmeister
                      • 43
                      Hi mate,
                      these are the patched files required for you to auto update when they do roll keys. They normally reside in \var\keys (or \var\scce) on your dreambox folder structure. These particular files can be found on the bigmaq toolbar under Files & Fixes.
                      • woody65
                        • 7
                        Hi , Thanks.
                        I tried that for the SBO cant see anything as yet. I did the bouqet for the Adult channels as said by pasting into the file and ftping back to the box. The channels all apear in the bouqet, but none of them show - i get the message - "no data for this service available".
                        Whats going wrong? I think I am EX TW. Also where do I get the ARY, B4U etc keys from . Getting frustrated as not getting anywhere fast. Have retraced all my steps carefully. Have started with autoscan using 6927. pls help all appreciated.
                        Maybe someone has file with ALL bouquets set , so that I can add them to file and ftp across- that would be really helpful. im pretty sre I am ex TW.
                        cheers
                        W
                        • jpd
                          • May 2010
                          set up box but nothing is happening help
