After a lot of help from you guys on here I have successfully sorted my box out but I am missing sky sports one and E4 , can anybody tell me if I can get them back ? if so how? i have done a scan again but no luck !!!!
help please some channels missing
Missing channels from a scan is 99% of time down to signal strength.
Disconnect all splitters and connect the dreambox direct to the main feed. Do another scan and see if you get SP1 back. If you do, then you know it's a signal issue and you'll need a signal booster or better quality splitter.Comment
Never used one myself but I would imagine it's a case of using a normal aerial cable.
Try adding it right behind the dreambox and right after the feed comes into the house. See which signal level is best.
Menu > Information > Stream Info > 3rd page
Note the SNR value, this should be > 92% (approx.) before you'll get all the channels.Comment
but really want SS1
