Sagem dbox
  • wolfydingle
    Sagem dbox
    Hi Eveyone, New to all this and in need of help,well my dbox as froze it won't switch off using the remote control and on the front it says kein system could anyone tell me what i can do to fix it please kids doing my head in because they havent got hundreds of channels thanks Wolfydingle
  • Knockoff_Nigel
    • 69
    Hi m8, unfortunatly with the message Kein System on your box you will need to enter the wonderful world of Flashing.
    The Kein System is German for Wrong System I think,could be No System, but basically the image/software that was enabling you to watch all the channels has went corrupt.
    You will need to d/load a tutorial and a new image to Flash your box, the tutorial if reead properly will enable you to do this.
    • wolfydingle
      Thanks Knockoff Nigel i will look into that
      • humbucker
        • 7
        Just sorted mine out as the image was supposed to be a 1x and it was a 2x.
        I only found out after I downloaded the latest Dbox image flashing assistant and this showed me the file was a 2x image.
        Downloaded another 1x image and all is well.
        You will need a null modem cable tho.
