Dreambox 500c / Eurovox Ultra
  • billiedog
    Hello, can anyone help. I have a Eurovox Ultra which I think is the same as a dreambox 500c. I have tried to reflash it using a guide in the forum but all that it does is nothing. No picture no sound no response from the remote. The green light is on. Thats it.
    Someone mentioned arom update. That has lost me. I have only had the box 3 weeks.
  • smirnoff_rules
    • 8603
    when it was working wot did the screen say
    it should take this image http://www.digital-kaos.co.uk/forums...p?do=file&id=1
    • C64
      • 2394
      The EV Ultra is a DM500 clone and it does use the sme software as any other Dreambox, what you need to do is transfers a file from your PC to the box, have a look in the stickies and you'll find a few tutorials explaining exactly how it is done.
      • chiraju
        • Oct 2008
        • 27
        Hi Friends,
        I have a Eurovox Ultra box, which I understand is a DM500c, On last Monday 27th Oct I lost all the channels, so I decided to reflash my box so I used a image for dm500 and again I only got free to air channels no sky (I have copied the latest nagrarom keys available from that (xyz) tool bar but still no luck.
        I live in Reading
        Any help will be much appreciated, I am feeling like I have lost a world without my box working ....
        • thered
          • 4915
          i think you need to find out what your box is m8 is it a dreambox or a eurovox
          you say you flashed an image which one? where did you put the keys
          • chiraju
            • Oct 2008
            • 27
            Eurovox Ultra
            Hi,
            It is a Eurovox Ultra, but after reading through this forum it was mentioned that Eurovox Ultra is a clone of DM500c, that is why I mentioned it as DM500c ..
            I downloaded a image which is from techwatch forum, which booted the box up but with no sky channels. I copied the keys to /var/keys
            Any help is appreciated.
            • thered
              • 4915
              so you have a working image did you put the roms in the scce folder var/scce
              • chiraju
                • Oct 2008
                • 27
                Hii
                Hi.
                No I copied the keys nagrarom7 , nagrarom10, nagrarom 11 in to /VAR/KEYS folder.
                Should I copy them in to /var/scce folder?
                • thered
                  • 4915
                  yeh take them out your keys will probably be in 2 folders keys and scce keys go in var/keys scce in var/scce
                  if not just take all the roms out and put them in the scce folder it should work that is if you have the right keys
                  • chiraju
                    • Oct 2008
                    • 27
                    Thanks,
                    will do this first thing in the evening, I downloaded the keys from bigq tool bar, any other locations where I can look for the keys which might work ???
                    • thered
                      • 4915
                      they should be ok but il send some that definately work
                      • chiraju
                        • Oct 2008
                        • 27
                        Thanks, have a great day,
                        • chiraju
                          • Oct 2008
                          • 27
                          Finally I got my box working, one important thing I noticed is flashing the box with DW.IMG (1.6.5) via dreamup worked with the latest keys, where as it failed with DW2.1 image.
                          I have no idea what could be the reason, and also loading the image to /tmp folder and selecting manually update the software version didn't make the box working.
                          So 2 lessons learnt ...
                          Thanks to thered for the keys.
                          • Abid
                            • Oct 2008
                            Hi there
                            blackbox 500c not responding to any commands from remote control ,gone into freeze up mode, and I could not reboot from pre installed software , only blue light on permanently.Any suggestions or downloads, Please advise,,, Many Thanks
                            • chiraju
                              • Oct 2008
                              • 27
                              Hi.
                              I have a eurovox ultra which is a clone of eurovox ultra, how ever my guess is your image is corrupted so try uploading a proper using dreamup and a null modem cable, if you are box is not responding for remote means it is not booting at all so you have to use a nullmodem cable with dreamup software and load a proper image (I have dw 1.6.5 image ..) I know it is old but I am happy with that ...
