dk 1.1
  • martycarter
    • 4
    DM500 dk 1.1
    hi
    can anyone send me a copy of dk1.1 with the fix already on i`m using dw 2.1 now but have signal probs with it was using nutrino image before with out any probs
    cheers for any help
  • thered
    • 4915
    you can d/load it off here m8 then all you need to do is add the keys its straightforward m8 you will get the help you need
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      http://rapidshare.com/files/170257909/backup.img
      • glyndwrw
        • 5
        How do you add the keys
        • dreadfand
          copy the new rom files via ftp to the var/scce files or var/keys folder depending on the image your using. a step by step guide can be found as a sticky at the top of the cable dreambox section of the forum
          DREADFAND
          • glyndwrw
            • 5
            Many thanks Dreadfand I,ll give it a go
            • portbhoy
              • 717
              You must have missed this then
              • glyndwrw
                • 5
                DK backup image
                I have tried what you said. I am able to load the image and collect the channels via the transponders but I am unable to view prem channels. I used dreamup to install the DK image. Then I FTP,d the New Roms into the Scce folder. I then used the info button to start evocamd but I was still unable to view.
                I have now reinstated my previous DW 2 image that I had backed up.
                Have you got any further advice?
                Many thanks
                Glyndwrw
                • pwdpwd
                  how to emu NOVEL-TONGFANG ca?
                  • martycarter
                    • 4
                    just download the link above it has everything on it
                    • faulks6164
                      • 55
                      dk 1.1
                      what area are you in mate
                      • martycarter
                        • 4
                        teeside but it works on any area just rescan
