Cable.xml help??
  • sardine
    Cable.xml help??
    Hi,
    Can someone tell me what cables.xml is for??
    Will it give me extra channels?
    S@rdin3
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    cables.xml is the files that holds all the transponder data and frequencies. When you do an automatic transponder scan, it uses the data in this file.
    If it's for the UK then the scanning settings in your image are probably ok and an updated file won't get you any more channels.
    What's your problem?
    • sardine
      Thanks for your reply.
      I have only recently got my box up and running. Followed the instructions on Digital Koas. Worked first time - fantastic!
      A friend of mine also has a box but seems to be receiving more channels, he says its because he used the cables xml file.
      Also I have seen people make mention of slow or brutal scan. How do I do this? Will this get me more channels?
      thanks again
      S
      • toley
        • 8
        Is there a cables.xml file for Ireland?
        • smokey_jnr
          • 380
          sir fish....
          i am having probs with the subbed channels, i have the cam running but it won't unscramble the subbed channels.. i have put in the dbox roms in to the keys folder.. but that don't seem to work.. any ideas...??
          • Donnie Darko
            • 442
            Originally posted by smokey_jnr
            sir fish....
            Are all the magic files in the correct locations?and cam select from yellow or green button?
            Checkout the RED stickies massive amount of info and effort been put into them.
