problems with keys
  • thered
    • 4915
    problems with keys
    i have spoke to another person who is having problems with this so it aint just me
    i have a 7025c+s running with cccam problem is as cccam doesnt auto update i have been putting keys in manually as they change all has been well till yesterday now it doesnt seem to akknowledge the keys anyone else having the same problem and is there a solution
  • scuba
    • 198
    this might sort ur problem
    download and unrar ftp to ur box and change chmod (attributes) 755.
    press blue panel for update keys and select script and select HackSat_Key_Downloader and waiting to finished.
    • thered
      • 4915
      il give this a whirl tommorow cheers m8
      • thered
        • 4915
        just had a go doesnt seem to work with gemini image what image are you using
        • jbennett1974
          • 17
          hi have you tried using Mgcamd or Evocam on your cable channels or do you require CCcam to be on all the time
          DM800 (wow what a box)TM9100 Super 88CM Triax Dish Titanium 02 LNB Darkman Motor Cable Tuner
          • thered
            • 4915
            yeh it will work with mgcam but i need ccam on at all times really for c/s otherwise my shares are dead ducks
            • scuba
              • 198
              i am using dk image m8 and as for the cam for cable i am only using evocam 2.14
              • thered
                • 4915
                yeh i can get the cable auto updating using new rom 7 the problem is i need cccam running on my box as i run satellite and cable on the same box
                and for some reason i cant get cccam clearing cable on my box even when changing the keys manually (the same keys mgcam is using) but it still will not clear cable anymore
                • thered
                  • 4915
                  just to update is still no joy just a blank screen is anyone running cccam on a 7025 for cable
                  • scuba
                    • 198
                    don`t think u can use cccam for cable at all m8,just tryed it my self on my box won`t clear anything.evocam the only 1 that works for me.
                    • thered
                      • 4915
                      i can use evocam and mgcam and they both auto update and up until the other day cccam did work but i had to change the keys manually as and when needed only now it doesnt seem to acknowledge them at all
                      but if i switch emu it knocks all my shares in c/s off as i use cccam as the server and if i continue to show as offline in c/s people will start dropping me from their lists
                      • scuba
                        • 198
                        what i noticed with cccam on my sat box if i use 2.0.10 version it would reset my box all the time try maybe and use older version if u r using the 2.0.10.(just a thought)
                        • thered
                          • 4915
                          i was using 2.10 but i went back to 2.09 seems a little more reliable i have tried 2.11
                          but all to no avail i know of 1 person having problems just wondering if anyones having the same chew
                          • shady77
                            • 982
                            no im not.
                            but ive only got cable
                            • thered
                              • 4915
                              you clogging my posts again
