HD PVR
  • lanun
    • Jun 2011
    • 5
    DM800 HD PVR
    hi guys. just bought this recently.
    some additional info i got:
    ramimaher.experimental
    newnigma2 v 3.2.20110-32-4
    during startup, the oled will show a link Free Dreambox Images Download (Only for NEWB DM800 SIM2)
    is it a clone?
  • lanun
    • Jun 2011
    • 5
    starting to have a few problems now.
    few days back, some channels wer uration failed. so i did an automatic service scan, but i forgot to disable clear before scan.
    now my channel list is all in alphabetical order. i can't key in numbers to change the channels.
    i also noticed that the channel playhouse disney is missing. any way to get that back?
    lastly, almost all my free to air channels are pixelated. all the other channels are fine.
    help?
    --- this problem is solved ------
    • ypvs125
      • Dec 2010
      • 506
      help?
      There's an updated bouquet for SG in the download section and transfer them using dreamboxedit. Save yr current bouquet in case you want to revert back.
      • lanun
        • Jun 2011
        • 5
        is disney junior the old playhouse disney channel for SH?
        regardless, i've uploaded this bouquet
        Digital Kaos - Downloads - Service & Bouquet For DM 800
        but when i switch to disney jr, it says tune failed.
        i foolishly reset to factory settings without making any backups at all. that was a few months back, when i just got the box & had some problems. yea stupid of me right? does that have any effect? do i have to reupload any keys or some sort?
        oh & is there any better bouquets for SH HD channels that's recently updated?
        • Shady
          Shite Link King
          • Dec 2010
          • 6404
          yep here
          post 958
          • lanun
            • Jun 2011
            • 5
            all of a sudden, my clone dm800hd decided to play punk with me. after bootup, the oled display would go blank and the red led will keep on flashing indefinitely.
            i tried updating to several versions of the bootloader, from 76 to 82 now @ 84.
            so it turns out i needed to reflash the image. with tons of variations out there, i decided to go with Digital Kaos - Downloads - Sim2-vti.mod-dm800-84b
            i don't need tons of features, just happy to watch tv. most importantly the interface should be simple.
            after a successful flash, i did a service scan. but only free to air channels are viewable. did some reading up, i think i need some form of keys eh? now where do i get those?
            • ASTROBOX
              • 163
              This is what happen when u kanciong u should have read this link to update your channel list
              & why of all things u flash a different ssl to your box
              unnecessary, the images that your supplier install is already a patch images which i don't know which ssl, DID U KNOW?
              & u should have make a backup of your keys & rom files 1st before u do anything to the box as this backup things is already mention from most seniors & even junior who read & ask before doing anything stupid like this
              • lanun
                • Jun 2011
                • 5
                thanks for the reply sir. yes i have to admit that it was a stupid action and decision. i tried all the possible ways to backup the required stuff to no avail. the only thing i managed to get working was accessing the webpage where you can recover/reflash the image.
                before that, i tried ftp. even a software called flashwizard pro. same results, no way to access the clone dreambox. i also tried a crossover cable to connect my laptop directly. same results as above. and after spending the whole day reading all the possible threads, i finally gave up and pulled the trigger to flash a new image. yes, stupid i know. thanks for the reminder.
                what is the next course of action? is this a dead end?
                • ypvs125
                  • Dec 2010
                  • 506
                  Are u able to ftp to yr box now? By flashing new image, u need to do all settings. U need to scan channels, install softcam, ftp yr keys & roms before u can view paid channels.
                  • ASTROBOX
                    • 163
                    If u already flash
                    the next step is to communicate with box if all went well use DCC to send your AU keys, softcamd keys & rom files to their respective folder if still difficult to get than ask your supplier to issue u,
                    use DB edit to send
                    Digital Kaos - Downloads - SGSH 27072012 E2 800 & 800SE + Picon
                    restart mgcamd_1.35_ that is already pre installed with the images.
                    If u can watch those encrypted channels than u have done as most of us who done it. The next step use DCC again edit the softcam keys 00 01 to FF FF restart box see if the AU that u have works
                    • z3r0cool81
                      • Jul 2012
                      • 19
                      Hi all,
                      I have Dreambox DM800 HD PVR.
                      The last few days I put the box on standby mode & if I am not wrong, there are some recordings to be done. The hdd is attached to the box.
                      I tried to turn the dreambox on but it gave and error and started to reboot. After a few reboots, it hang in the loading screen with the dreambox showing
                      Sim201 team#84B
                      Sunray Sunshine SIM2 Free Images Download (Free for SIM2.01/SIM2.10) dhcp...
                      /flash/vmlinux.gz
                      the tv screen will only show the newnigma2 white loading screen.
                      Any pros know what could have been the problem and how should I go about to solve it?
                      • yenlrub
                        • Sep 2012
                        • 9
                        thanks!
                        thank you for your updates.
