For those still having problems with auto updating...read here
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    #16
    Delete everything in your /keys folder and replace it with the contents of the keys folder from the link in the first post.
    Go to Sky Sports 1 and reboot the box.
    Make sure you're using evocamd or mgcamd.
    • maniac2
      • 23
      #17
      Great info.Keep it up Kaos.
      • dkRookie
        • 5
        #18
        Many thanks to Devilfish, spent hours trying to get new images to work without any joy. Resorted to old Sportster image and applying this fix to make it work. Thanks again!
        • quark01
          • 16
          #19
          thanks for this brilliant
          • stellarocksme
            • 9
            #20
            Lol where do i find gemini 3.4 ?
            Thanks all.
            • charlie senator
              • 174
              #21
              Isn't that the one that fries your box if its a clone ?
              • muti
                • 11
                #22
                Can i watch Multivision Tps with this way? Thanks
                • Devilfish
                  Administrator
                  • Feb 2008
                  • 7872
                  #23
                  No...different Autoroll.key and AutoUpdate.key files would be needed for that package.
                  Try the new Mgcamd_1.30 emu, that should AU on TPS.
                  • kagon
                    • 140
                    #24
                    Thanks all.
                    All Gemini Project images can be found at:
                    • dotcom
                      • 5
                      #25
                      Mucho Gracias
                      • HUPextreme
                        • 30
                        #26
                        mentioned in another thread i notcied you mentioning to add nagraroms to /var/scce. but it seems that all the nagraroms go in the keys folder. Sorry i'm a complete noob, just trying to get the full understanding of how the roms, keys and image work.
                        • kagon
                          • 140
                          #27
                          On some images /var/scce and /var/keys are the same directory (/var/scce is a symlink to /var/keys or vice-versa). Most cam daemons are indeed looking for the roms to be in /var/scce it's just that as I've already mentioned often /var/keys is the same directory.
                          • HUPextreme
                            • 30
                            #28
                            cool, thanks kagon for clearing things up for me.
                            • kagon
                              • 140
                              #29
                              No problem. If you're curious what files your particular cam daemon has open you can do the following from a telnet or SSH session on your Dreambox:
                              ps auxww | grep <cam_name>
                              The second field should be the process ID (PID). At which point you can:
                              ls -al /proc/<pid>/fd
                              An example from one of my Linux boxes:
                              # ps auxww | grep syslog
                              root      3704  0.0  0.1   3560   940 ?        Ss   May20   0:00 /usr/sbin/syslog-ng
                              # ls -al /proc/3704/fd
                              dr-x------ 2 root root  0 May 28 13:47 .
                              dr-xr-xr-x 5 root root  0 Jan  1  1970 ..
                              lr-x------ 1 root root 64 May 28 13:47 0 -> /dev/null
                              l-wx------ 1 root root 64 May 28 13:47 1 -> /dev/null
                              l-wx------ 1 root root 64 May 28 13:47 10 -> /var/log/dhcpd.log
                              lrwx------ 1 root root 64 May 28 13:47 11 -> socket:[8574]
                              lrwx------ 1 root root 64 May 28 13:47 12 -> socket:[8801]
                              lrwx------ 1 root root 64 May 28 13:47 13 -> socket:[60239]
                              lrwx------ 1 root root 64 May 28 13:47 14 -> socket:[8924]
                              l-wx------ 1 root root 64 May 28 13:47 16 -> /var/log/auth.log
                              l-wx------ 1 root root 64 May 28 13:47 17 -> /var/log/sudo.log
                              l-wx------ 1 root root 64 May 28 13:47 2 -> /dev/null
                              lrwx------ 1 root root 64 May 28 13:47 3 -> socket:[6370]
                              lr-x------ 1 root root 64 May 28 13:47 4 -> /proc/kmsg
                              l-wx------ 1 root root 64 May 28 13:47 5 -> /var/log/messages
                              l-wx------ 1 root root 64 May 28 13:47 6 -> /dev/tty12
                              lrwx------ 1 root root 64 May 28 13:47 7 -> socket:[7007]
                              lrwx------ 1 root root 64 May 28 13:47 8 -> socket:[7993]
                              lrwx------ 1 root root 64 May 28 13:47 9 -> socket:[8137]
                              I'll try and update this with a Dreambox specific example once I'm at home and can shell into it (it's unfortunately off at the moment).
                              • deanofire
                                • 27
                                #30
                                excellent post worked a treat first time thanks a lot.
                                only thing is not sure how to check AU in the camd_cfg file is set to enable ?
                                but am up an running for now which is great.
