Dream Control centre (Bootmanger)
  • mcrabb85
    • 11
    Could someone please explain what the bootmanger is as when I connoct to my box from DCC is says bootmanger not found.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    DCC always says that for me too and everything is setup ok.
    I don't like DCC...too many things all crammed into the one application. I guess it's good if you're starting out but can be difficult to set up.
    Don't worry about that error.
    The bootloader is like the bios, it boots the box. Without the bootloader, the box would be nice looking ornament in your living room. If you try to flash an image that's meant for another type of box, you'll corrupt the bootloader.
    • mcrabb85
      • 11
      Thanks for the reply I must admit I was only using DCC to change the key files I used it to flash my box and it did not work properly
