Dead 500c
  • northamptondave
    • 13
    Dead 500c
    hi i have tried to reload 2.0 and it flashed accross ok - but the box is still totally dead - just green light - remote doesnt work with it? tv not picking up a signal. is it possible that i could have overloaded the boxes memory? if so can i delete the files on the boxes memory? any help would be appreciated - thanks dave
  • C64
    • 2394
    Sounds like it just needs a reflash mate, grab Dreamup connect your serial cable and reflash.
    Remember you will need a serial cable (null modem cable) and Dreamup, you cannot FTP to the box whilst it's in that state.
    • teleboss
      • 59
      I had the same problem, Just used the lastet Unviversal DreamUp V1.3.2.1 and uploaded a image no problems, make your self up a null modem cable and away u go.
      BTW the Digitalworldz image seems to be missing a lot of the providers in the drop down menu, Is there some where I can download the difference, i saw another dreambox with this on it.
      • Curious123
        • 2591
        If you saved your services & bouquets than just export everything back to your dreambox and you should have everything.
        • richjon
          • 4
          check all your feed cables are connected correctlly, as you might not be getting a signal
