channels not working
  • condor
    • Oct 2008
    • 17
    Hi, I've been away on holiday all week and have come back to no channels. Before i went away i sorted the auto update feature with the new ROM 7 file and everything worked great. Now having come back i am only getting FTA channels.
    the keys have updated today but still nothing.
    HELP!!
    any ideas?
    ps im doing a rescan to see if that works..
  • davemac82
    • 279
    HELP!!
    any ideas?
    let us know how the scan goes m8 if it doesnt work try applying the fixes again.
    • scuba
      • 198
      try and change the cam,press and hold the info button for few seconds.
      • condor
        • Oct 2008
        • 17
        the channel scan locked up after an hour. so i switched off and on again, but still didn't get anything. i've checked the emulator and its using evocamd. it doesn't appear to be updating..
        got it working after i manually entered the keys. so im gonnae try reapplying the fix and see what happens. cheers for the help guys..
        C
        • red devil
          • Oct 2008
          • 690
          best bet is re flash wit ur backup, u did make a backup right ? had same prob a few times dat should sort it
          • Dazmeister
            • 43
            C
            I had the same problem mate after applying the update, turned out I hadnt updated the AU to 02 in keylist.txt, was set to 01 so didn't auto update.
            • SMORT40
              • 15
              how do we get to the key list menu and what should the settings be reflashed the box applied the fix but no ppv channels are available
              • scuba
                • 198
                u can access ur key file with ur remote,depending on the image u r using for the dk:
                press the blue button>tuxbox commander>var>keys>highligt keys.txt and press 4 on ur remote(u r now in ur key file)>highlite the line with a wrong key and press ok>change the incorrect number or letter>press ok>press red to save changes 2ice>exit to the clear screen>restart ur cam
                • welshbhoy
                  • Aug 2008
                  • 25
                  Sorry to jump on this thread.......(This has happened after the latest reflash) But I have an issue with Tuxbox commander. When I try to access it I get a message telling me of a fatal error. The box then reboots and I get a few channels, some FTA and some others. I don't get, movies, sports or Setanta.
                  Any ideas or solutions. Should I reflash it? If that doesn't sound too stupid a question. (This was before it all went pear shaped) It's just that a while back I tried to manually update the keys in tuxbox and there was something missing and although tuxbox seemed to be there from various pictures I've seen showing how things work I still had a fatal error message. I can't explain it properly, but if you imagine looking at the two sides of tuxbox commander there was something different about the one side from the images I saw. Don't remember what exactly.
                  Is tuxbox built in with the DK flash or should I apply it to the box myself?
                  By the way it's a dreambox 500c.
                  • scuba
                    • 198
                    ye m8 just reflash it and it should solve ur problem.the dk image comes with tuxbox in it.
                    • welshbhoy
                      • Aug 2008
                      • 25
                      Cheers mate, will do.
                      • one of 147
                        Some channels not working on my Dreambox 500C
                        I have had my Dreambox 500C for a few weeks, I had it flashed by a friend as I havn't a clue how to do it myself. It worked fine but a few days ago some of the channels have 'gone missing' Some FTA channels and also some pay channels. Any ideas on getting them back?
                        • paxo12
                          Try a rescan mate.
