how to change auto update ?
  • grahamxs500
    • 25
    hi
    done everthing to get box back with key change (dm500) but how do you activate auto update / is it through flash fxp or with remote
    cheers graham
  • father ted
    • Feb 2008
    • 1389
    Originally posted by grahamxs500
    hi
    cheers graham
    unless you have changed it manually you dont need to do it if you have put the new files in correctly and its working it does it all for you
    • grahamxs500
      • 25
      cheers for reply
      reading the file with flashfxp its on a (01)
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Yes the AU should be set to { 02 }.
        • bigsteve101
          • 20
          dm500
          If using evocamd try copying the rom files into the scce folder as well.
          • grahamxs500
            • 25
            cheers for the help / have change the camd_cfg and mg_cfg to (02) edited and saved with flashfxp .
            but cant find gbox - gbox_cfg /thats mentioned in au update does this matter
            cheers graham
            • grahamxs500
              • 25
              have already done that cheers
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                Gbox will not work. The nagraroms are built into the gbox file and this can't be edited. So until a new version of gbox is released, which is highly unlikely, you can't use this anymore.
                Evocamd is your best emu to use.
                • grahamxs500
                  • 25
                  thanks for the advice kaos and every one that helped / glad i came to this site as im learning all the time and everything is explained brilliantly
                  cheers graham
