HELPPPPPPPPPP
  • RBJKO
    DM500 HELPPPPPPPPPP
    hiii
    my receiver DM 500-S
    i need a code for the parental lock
    just code pin for parental lock . 4 number
    i d ont need root ... just number
  • shady77
    • 982
    i take it you've tried 0000
    if not according to the manual, you'll have to factory reset it
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      FTP to /var/tuxbox/config/enigma and find a file called 'config'.
      Right click it and select 'view'.
      Look for a line like...
      parentallock=00000000
      Open up your windows calculator and go to scientific mode.
      Click on the HEX button.
      Enter in the last 4 characters in the parental lock line in the config file.
      Click the DEC button.
      This is your 4 digit pin code. You can then use it to disable the parental lock or Setup lock on your image.
      If you can't ftp, your only option left is if you have the tuxbox commander plugin installed in your image, in the plugins menu (Blue or yellow button). You can navigate to the config file using this plugin and edit the file here.
      • shady77
        • 982
        wow DF! You are REALLY clever!
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          • mm009b
            • 221
            nice one devilfish
