What exactly does a Dreambox give you?
  • carlbcfc
    • Apr 2009
    • 18
    I see the stickys, guides etc.. but I still do not know exactly what channels I will receive should I but a Dreambox. I had a Eurovox before Nag 3. Am I right in assuming it is more or less the same?
    Just a bit confused as I see all the guides, but no actual explanation of what it is capable of.
  • andy91
    • 3583
    Door stops for most cable systems and fta on sat section.
    Have a google on cardsharing that might point you in the right direction mate.
    Andy.
    • carlbcfc
      • Apr 2009
      • 18
      Cheers bud. Found a good site that came top of google search. Any recommendations on a box & dish for this setup?
      • billy2
        • 1381
        will all come down to ?????s m8 what you wont to watch. a sd box will come in around ?50 plus dish and lnb, a hd box will come in at ?120 give or take if you get one from china and about ?160 in the uk plus the cost of a dish and lnb. dish size will come down to where you are and wont you are looking to watch as there are alot of sats out there
        • carlbcfc
          • Apr 2009
          • 18
          I would go for HD. ?250 I would guess. These boxes with this dish, as well as being able to view Sly with he cs, would I also be able to get the foreign footy etc via other sats?
          On another forum somebody recommended this, heard of it?
          "boxee. co uk ?120 for the box, internet connection, reads any format, winner!"
          • TheCoder
            • Jun 2011
            • 693
            Or, if you have an old PC you can just download the software and get the same facilities for ?0
            tbh though, it really doesn't give you much more than any internet connected PC, maybe just slightly easier to use for those not familiar with using a PC
            • carlbcfc
              • Apr 2009
              • 18
              Cheers.
              So any recommendations for a HD box, dish, and lnb (btw, what is that?) And, can this cs capable setup also do the Sat3pm footy?
              • thefantom
                • Dec 2010
                • 46
                Dreambox 800hd or hd se. 1 meter dish. Icecrypt motor and a cheap starview 0.1 DB lnb. All for under ?250 !
