Picky DK image question
  • Sirus
    • 340
    Is there any config files I can edit within the image so that I can switch my back/forward buttons around with my volume keys so I can change bouquets using the main middle part of the remote much like other images do
    I dont want this to sound like a rant, its a great image and all but I just am so used to it being the other way round were when you press OK to bring up a bouquet channel list then use volume left/right buttons to jump bouquets
    also the back/forward arrow keys in the DK image are back to front I think, cos when trying to return to a previous channel I have to hit forward arrow instead of back... and also I had to set up my bouquets backwards to compensate for this also.. for example my bouquets are something like this-- local -- popular -- movies --sport -- music -- etc... but if Im in my movies bouquet and hit the forward arrow key it jumps to popular instead of sport if you know what i mean so I had to align them all backwards like above only in a decending list to compensate for my forward button bringing me the right way I like it to be, but when I do that it means BBC 1 is something like channel 277 and stuff instead of it being no.1 as in the first bouquet (it has to be the last bouquet for the arrow keys to work proper)
    Is this a glitch a bad flash or is there an easy way round it.. thanks
  • despdan
    • 544
    Hi
    try
    usr/share/tuxbox/enigma/res
    • Sirus
      • 340
      Thats the file Im a looking
      Thanks alot dude
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        I've seen the backwards bouquets thing before and not on the DK image, I've flashed a few boxes with the image and it's never happened so I think it's down to a bad flash and I have no idea how it's caused. I'm sure a reflash would sure it.
        The file you want is /share/tuxbox/enigma/resources/rcdm5xxx.xml.
        But you can't upload to this location as it's read-only. Put the edited file in /var/tuxbox/config/enigma/resources and it will be used before the one in /share.
        • Sirus
          • 340
          No probs Devilfish, glad to hear the backwards thing is just a bad flash glitch.. guess Id better try a reflash
          I found that file after despdan posted and was trying to mess around with it in Tux and couldnt edit it and was going to just FTP and rewrite the old one, so thanks for the last bit of info on putting the edited one in the other directory
