dm500+ is only satellite version?
  • booyoo
    or exists for cable too? thanks
  • caveman_nige
    • Feb 2008
    • 4920
    From what I can see from the manufacturers data is seems to be only available as a sat receiver
    250 MHz PowerPC Processor
    - Linux Operating System
    - 2 LED status
    - MPEG-2 Hardware decoding, DVB-S
    - 1 x Smartcard-Reader
    - 1 x Scart-interfaces (RGB, FBAS or S-Video)
    - V.24/RS232 Interface
    - 10/100Mbit compatible Ethernet Interface
    - analog modem
    - S/PDIF Interface for digital bit stream out (AC-3)
    - 32 MByte Flash, 96 MByte RAM
    - unlimited channel lists for TV/Radio
    - channel-change time < 1 second
    - automatic service scan
    - directly bouquet-lists
    - EPG (electronic program guide)
    - Videotext Decoder
    - multiple LNB-Switching control (DiSEqC)
    - OSD in many languages and skin-support
    - extern12V power supply
    DreamBox DM500 + technical data
    DBS-Tuner:
    Frequency Range 950 …. 2150 MHz
    Signal Level - 65 dBm …. - 25 dBm
    Signal-to-Noise Level 12 dB max.
    DBS-Tuner Input Connector F-Type female
    Input Impedance 75 Ohm
    AFC +/- 3 MHz
    Demodulation Shaped QPSK
    FEC Viterbi and Reed-Solomon
    Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8
    Roll-off Factor 35 %
    Demultiplexing according ISO 13818-1
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible
    Video Standard PAL G/ 25 Hz
    Video Formats 4:3 / 16:9
    Letterbox for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II
    Audio Mode Dual (main/sub), Stereo
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk < -65 dB
    Output digital:
    Output Level 0,5 Vss on 75 Ohm
    Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Output optical (AC3)
    Video parameter:
    Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
    Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    Output: FBAS, RGB, S-Video
    Serielle Interface RS 232:
    Typ RS232 bidirectional
    Bitrate 115,2 kBit/s max.
    Plug Connector SUB-D-9
    Function: Update of Firmware
    Ethernet:
    10/100 MBit compatible interface
    LNB Power and polarisation:
    LNB Current 500mA max. ; short-circuit-protected
    LNB Voltage vertical < 14V no load, > 11,5V at 400mA
    LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
    LNB shut-off at Standby-Mode
    Count of active satellite position:
    DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
    DiSEqC - Rotor Control
    Power consumption:
    < 10W / 12V
    Input voltage:
    DC12V +/- 15%
    Extern power supply:
    Input: 110-240V AC / 50-60Hz / 0,6A
    Output: 12V = / 1A or 2A
    Physical specification:
    Ambient Temperature +15?C...+35?C
    Humidity < 80%
    Size (W x D x H): 195 mm x 130 mm x 40 mm
    Weight: 0,6 kg
    • booyoo
      Thanks, so it means all the shops currently selling the DM500C is not a dream original?
      • osborne82
        Dreambox Guru
        • 133
        yip been like this for well over a year although theres still a few peeps that "think" they have bought a orig
        cheers
        osborne82
        • 2tone
          • 483
          more than sure sms dreambox shop have real ones in stock as he got the last of them and he is the uk dealer for dream but there 159 m8 they are def real ones know some one that got one a while back and its def real dont think he would risk selling clones if he is the main uk dealer
