Plugins not showing up after install
  • kokoronikui
    • 73
    DM800 Plugins not showing up after install
    I am a new dm800hd user. Currently, box is flashed with enigma2. My box is connected to the net. When I select any plugin to download, it always reports as successful. I see a window which is something like this :
    but it doesn't appear in the list. What am I doing wrong.. thanks for your help
    Anyway, if I want to try to ftp, can someone tell me the default plugins folder so that it can be done manually?
  • lincsat
    • 1228
    You need to restart Enigma for them to show up.
    Most plugins want installing properly, you can manually install by transferring them into /tmp/ then use the manual installer in most images. For a totally manual install, the folder goes in /usr/lib/enigma2/python/Plugins/Extensions/
    • kokoronikui
      • 73
      Thanks for your advice. I never thought a restart was necessary. Will try again
