Both boxes use similar (but different) versions of the same software, and so far no-one has been able to get theDreambox to extract the necessary info from the stream, you can however use plugins which (when connected to the Internet) will give you a program guide for up to a month!
why I seems forever running out of memory in dreambox 500 to add any plugin? there are few very good EPG plugin from various image. does anyone had the same problem?
Most of the EPG plugings store the EPG data on either the hard drive, compact flash or USB stick. A 500 can use none of these, that could be why.
500c, 600c, 7025+cc, 7000s with a 1m steerable dish
