Freezes since 23 Dec Key Change
  • harry1986
    • 516
    Since the auto key change 23 Dec any channel that i watch for sometime freezes and then i have to go to another channel and go back again to make it work again i dont know why this is happing never happened before and i know it isnt a signal problem can any1 help ?
  • C64
    • 2394
    I'd still investigate the signal levels mate
    Have you try alternating the Ucodes?
    • harry1986
      • 516
      yes i changed em b4 but still same problems
      • harry1986
        • 516
        how do i change the ucodes on a dreambox 500c?
        • shady77
          • 982
          ? thought you'ld said you did it already?
          To change the ucodes press blue button go in to settings then go to ucodes selection, go to ucode 001a and press ok then restart your dbox. If this does not work try one of the other ucodes.
          • harry1986
            • 516
            na i thought i done it erm wen i press the blue button i get the following
            DreamNetcast Internet Radio
            RSS Newsreader
            Tuxbox Commander
            Teletex
            where do i go from here now cox i cant find the ucode section?
            • shady77
              • 982
              sorry harry my bad for some dopey reason i thought you had a dbox!
              what a twat i am.
              • harry1986
                • 516
                na yur not a twat man yur a safe guy thanks,do yu no how can i change the ucode on dreambox?
                • shady77
                  • 982
                  no mate i dont. i've literally this second give up looking in the tuxbox and on the web. cant find anything mate. witchy will be along in a min no doubt to fill you in
                  • Devilfish
                    Administrator
                    • Feb 2008
                    • 7872
                    There are no ucodes on a dreambox.
                    Are you using MGCAMD as the emu? If so, switch to evocamd. Mgcamd is known to cause freezing issues.
                    If you are using evocamd, check the SNR % in MENU > INFORMATION > STREAMINFO > RIGHT > RIGHT. This needs to be about 96% for optimum viewing. I'd say lower than 92% you will get freezing. In this case, you'll need a signal booster. Try connecting the box to the main feed temporarily to see if the SNR % increases and the freezing stops, if it does, you'll need a booster.
                    • harry1986
                      • 516
                      safe mate thanks for looking cheers
                      • harry1986
                        • 516
                        thanks devilfish
                        • trickykid
                          • 89
                          that happened to me around a year ago. I was using mgcamd. When i changed to evocamd 2.12 all problems were gone. Sometimes the picture looks like step by step (slower), but when i restart the cam everything comes back to normal.
                          Which cam are you using??
                          • harry1986
                            • 516
                            im using ecocamd 2.12 and used 2.17 before to i think its all sorted now changed the feed adaptor so hopefully should be fine
                            • trickykid
                              • 89
                              excellent, let us know how you get on
