help i have no idea i have dreambox control centre
get all channels back do i need an update. i myself have a eurovox max box which i can put codes in manually the dream box uses a linux interface and it wont auto update anymore i am connected to it using dreambox control centre ftp mode can see all files on the dreambox but what do i do next
the control center help to transfer file.just check if your ip address :192.168.1.xxx is the same at one on the communication setup in the box.tick the box how you are been connecting.ie crossover or router clik search .it bring up ip all ip address choose one the same to communication setup and click accept.then the connection would be established.
