Need help
  • ypvs125
    • Dec 2010
    • 506
    #16
    Originally posted by afigirwansahh
    Well its a no, thanks so much will try after i buy both of the cables...
    Have a look here to find a compatible usb to rs232 converter for our box.
    • afigirwansahh
      • Oct 2011
      • 11
      #17
      Sorry people but I had another problem! I buyed the wrong cable m/m came with a USB to rs232 connector... I really wanna flash it so bad so does anyone know any other method to flash it and Is it possible if I flash using a mini USB instead? Thanks!
      • ypvs125
        • Dec 2010
        • 506
        #18
        You can use telnet or flashwizard pro to flash image to yr box using the lan cable depends on situation. Is it able to bootup?
        • afigirwansahh
          • Oct 2011
          • 11
          #19
          Flashwizard pro can the program FTP?? Yes it does boot up but when the Pli home came up it started to flicker on and off..
          • ypvs125
            • Dec 2010
            • 506
            #20
            If there is an ip address for yr box, maybe u can try to flash image using flashwizard pro or telnet else dreamup is the only solution.
            • DBTraitor
              • Feb 2011
              • 616
              #21
              You can either buy from Sim Lim Tower or online below
              USB 2.0 to 9 pin RS232 COM Port Serial Convert Adapter | eBay
              A wise man learn more from a foolish question than a fool can learn more from a wise answer.
