im not liking dk1.1
  • dctyper
    • 2539
    im not liking dk1.1
    im finding it very unstable, cant press menu to delete a channel as it freezez with no options. i also keep losing the movie channels! has anyone else had an issue?
  • shady77
    • 982
    no. ive tried 3 different images and i've gotta say dk v1.1 is the best one
    • Digger
      • 154
      yeah i,ve found the dk image very stable have been usin it ages now, must be your signal in your area mate. Try a different image and c if its also unstable and compare then eh....
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Do a factory reset.
        When it boots up, do an automatic transponder scan. When it finishes, then do your thing, add bouquets, or keys or whatever.
        Should be ok then.
        You could always use another image.
        • C64
          • 2394
          DK1.1 is one of the best, most stable images I've used since 2002!
          • nilrem
            • 54
            I have had the same problem with the box locking up when u press the menu button to delete a channel and have had to power cycle it other than that I like it ....a lot faster than most of the images out there
            Cheers
            • dctyper
              • 2539
              ive found dw2.0 to be more stable, ive tested the box at other locations and had the same problem. ive done a rescan(full)now all ok. cheers chaps
