Multi channel ip streaming
  • Lostangel556
    • 4
    Hey,
    Ok, im a bit new to this so bear with me. i understand from reading the other posts that i can stream my dreambox via the network.. excellent.
    But is it possible to watch 2 different channels on 2 different pcs?
    this way i could send it out over my home and use it to watch tv on either of my computers while my gf does the same in our office
  • smirnoff_rules
    • 8603
    no m8 u can only watch the same channels shes watching
    • Lostangel556
      • 4
      damn.
      ah well, can always get another box i suppose for the office
      • perrin11
        • 6
        Watch two channels
        The dreambox is attached to a TV via composite out and to a PC via ethernet then you could watch two channels different channels, if you know the VPID and APID information for the channel you want to watch on the PC.
        Switch to channel you want on TV. Then on PC use vlc and open a network stream and enter the stream information e.g. http://192.168.0.100:31339/0,1085,0262,0263
        The above stream info is for BBC2.
        However, if the channel is changed then both TV and PC will revert back to same channel.
